Old 03-19-2008, 05:14 PM
Webslinger_94's Avatar
Webslinger_94 Webslinger_94 is offline
Send a message via AIM to Webslinger_94
Question 96 Grand Am Shaking problems
I have a 2-door 96 Grand Am that shakes when stopping/slowing and when accelerating after a stop. I have replaced the rotors and pad, passenger side cv shaft,
rear drums, and both front wheel bearings.
The problem is not the tires and is coming from the front driver side. It almost feels as if one of the tires are not balanced, but it stops just after about accelerating from a stop. I had the tires balanced anyway but the problem still remains. I also hear a sort of squashing sound coming from the front driver side tires, and just recently the sounds became loud enough to hear from the inside. A buddy of mine said that it may be the cv shaft on the driver side thats causing all of the problems. I wanted to see if anyone else would say the same thing or maybe something different.
p.s I don't know if this would help but the person that had it before me just let it go to $*&%
Old 03-19-2008, 05:24 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 96 Grand Am Shaking problems
It could be the tie rod ends, ball joint, or A-arm bushings. Just check to see if everything is tight and replace anything that is loose. Did you try rotating the tires to see if the shake moves to the rear? Not everyone watches the tire while it's on the balancer, and won't notice something as simple as a broken belt.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-19-2008, 05:47 PM
J-Ri I did have the tires rotated but the problem stays in the same spot
thanks for the reply though!
Old 03-20-2008, 09:43 AM
Anyone else who might think it's something else please let me know, I'm open for opinions
Old 03-20-2008, 06:07 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
The squasing sounds almost like a strut bottoming out because of a bad spring. It would cause some shaking.
You could probley see if thiers a piece broke off the end at the top, which is typicaly where they break, at the ends.
So it's shaking when moving, whether you are braking or accellerating ?
That could be a bad CV joint.
Grab ahold of the cv axle and see if it moves, it should not have any play up/down or side to side.
1999 Grand Am SS 3.4 OHV
