Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-19-2008, 03:20 PM
zachhoffer zachhoffer is offline
96 ciera Power window failure
All 4 windows died. 3 of the motors are new, I also replaced the fuse/breaker and changed out the driver control switch. somebody please have an idea for me.
Old 03-20-2008, 08:14 PM
caddyman379 caddyman379 is offline
Re: 96 ciera Power window failure
The wires frequently break in the drivers door boot. The others get 12v from the master switch.. So A break would cause all to go bad. This is almost certain if said door has excess up down movement because of a worn hinge or bushing. Either way, check it out, you can cut the boot and re-wrap it, or take the door off and pull it that way..
Old 03-20-2008, 09:46 PM
You are the greatest person alive
Old 03-25-2008, 01:53 PM
will1976 will1976 is offline
thanks man, I had the same problem. Your advice was right on...
Old 04-02-2008, 06:44 PM
jmikef21 jmikef21 is offline
I had the same problem with my grandfathers ciera. I ended up replacing wires with wires for trailer. I think it had like five or sebven wires all in a flat ribbon. Still working going on about 2 years since replacing.
