Old 03-19-2008, 01:15 PM
lostguy lostguy is offline
96 grand am wont stay running
My grand am 2.4 l dohc runs for 3-5 seconds and shuts off if you try to restart without shutting off key and restarting it won't turn over again just cranks. Have had battery and alternator tested and replaced all relays and fuses also changed ignition module and ignition switch in column since it was recalled and i was never notified..... right before it happened the gauges went nutso and all the idiot lights came on. I got it home shut it off and ran it back to the store came home shut it off and thats when it happened.... Can some one help me please before i burn it with me in it lol....
Old 03-19-2008, 03:39 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 96 grand am wont stay running
if it cranks then its turning over, you mean it just wont start again ?
Hav you checked your fuel pressure or replaced your fuel filter recently ?
Is it getting good spark from the coils ?
When you replaced the ignition switch, did you so a relearn procedure afterwards ?
1999 Grand Am SS 3.4 OHV
Old 03-19-2008, 03:44 PM
camaro0281 camaro0281 is offline
you dont happen to have an amp hooked up do you, i had my power wire burn and grounded itself out, and all the gauges went nutts and stalled. if not i would check the wiring at the starter, alternater and battery
Old 03-19-2008, 06:18 PM
Angry Re: 96 grand am wont stay running
I have replaced the whole ignition plate on top the motor piece by piece and as far as the fuel filter no i haven't but that is a good idea thanks it does however seem to have good fuel pressure and the pump runs strong. and for the other post no amp just factory everything in that field...and how do you do a relearn procedure???????????????
Old 03-19-2008, 07:03 PM
chevyrulespops's Avatar
chevyrulespops chevyrulespops is offline
Check to see if you have a trouble code in the ECM/PCM..you didnt mention checking that...those symptoms might signal a computer/ ECM failure too...if it is, I would go to the junkyard and get one...let us know what the problem was...hope u fix it!
Old 03-19-2008, 09:02 PM
Question Re: 96 grand am wont stay running
Can that be checked with my obd tool if the car is not running most cars have to be running in order to get a reading please let me know
Old 03-20-2008, 04:14 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I have never seen a car that had to be running to check codes, but yes, any OBD-II scan tool/code reader should work.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-22-2008, 11:44 PM
my next day off i'm going to try all your suggestions will post to let you know results
Old 03-23-2008, 09:20 AM
gebster76 gebster76 is offline
check the plugs...for misfire or something gas related
Old 03-28-2008, 10:48 PM
Car still not running found a blown pcm fuse but that didn't solve the problem
Old 03-29-2008, 03:58 PM
If the pcm fuse was blown, then something had to short out to blow it. These are never fun....
Did it blow the fuse after you replaced it and tried restarting it ?
Did you ever pull those trouble codes ?
Old 04-19-2008, 09:24 AM
Red face Re: 96 grand am wont stay running
Haven't got to pull trouble codes yet but have replaced fuel rail and pressure regulator. because when i dump gas into throttle body it runs until gas runs out.....
Could it stilll be the fuel pump even though pump runs could it be that there is not enough prssure comming from fuel pump to keep car running?
Old 04-19-2008, 10:11 AM
Sound like somethign in the fuel system not working.
Check your fuel pressure and you could try replacing your fuel filter if it hasnt been recently. If its clogged you wont get fuel.
Good Luck
Old 04-19-2008, 05:16 PM
preluder77 preluder77 is offline
I am having the same problem you are having. I tested the fuel pressure and it seemed fine to me. Pressure was above 40 even when my car stalled
. then the pressure dropped after the car stalled but my guage leaked alittle bit. How do i know if the fuel injectors are pulsing? I have noid lights but i cannot get to the injector plug. Please let me know if you find any soulutions.
