I am not getting any fire to the coil on my 89 plymouth voyager. I am going to change the ignition switch I have changed everthing else that I can think of if this is'nt it I am going to have to get a new brain I think if anyone can tell me something I am not thinking of I would be greatful thanks if the brain goes bad would that make my van just die while I was driving it cause I have changed about everything else that I can think of
jai Last edited by jai6479; 03-24-2008 at 01:17 PM. |
Re: not getting any fire
Which engine do you have?
What parts have you already changed? ANy codes? |
Code 12 is the battery has been disconnected in the last 50 cycles and 55 means end of codes.
You say that you have changed distributor cap, I am assuming you also replaced the rotor at the same time if not do so. Here is a site that gives you directions for testing the ignition system for no start: http://www.autozone.com/az/cds/en_us...rInfoPages.htm I recommend doing these test before replacing the SCC. Take off distributor cap and make sure the distributor is turning, if not check for broken timing belt. Hope this helps Last edited by tempfixit; 03-24-2008 at 04:46 PM. |
