Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-19-2008, 10:46 AM
rbhasychak rbhasychak is offline
Wont Start help!!!!!
ok I have a 98 NON-turbo talon and i just swapped the motor with new battery and alternator. But when i got to put in the key nothing at all will come on, no lights, turn signals windows, etc. I checked and there is power to the starter and the alternator, but there is no power to the fuse box under the hood or in the car. I am stuck, what should i check?
Old 03-19-2008, 10:51 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: Wont Start help!!!!!
Check your relays.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 03-19-2008, 10:55 AM
i checked the one's under the hood in the fuse box and they are fine and the one i found under the dash. Are there any more that would control something like that the hanes manual sucks when it comes to the electrical part of the car
Old 03-19-2008, 11:04 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Check and make sure you pluged everything in right. I believe power runs to the fuse box directly from the battery. Follow the wires that go to the fuse box back and see where they go.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-19-2008, 11:07 AM
JoeShmoe's Avatar
I would nect check the cam angle sensor and your ignintion. I don't want to give you a laundry list of things to search for and send you on the wrong path. But use the search bar and see what you can find. there's a lot of responses on this subject.
Old 03-19-2008, 11:11 AM
Holset powered 420a
He has no power to the fuse box. The sensor on the motor will only cause the motor not to crank.
98 Eclipse GS Turbo
2001 BMW 325i - DD
