Old 03-19-2008, 05:27 AM
GT11 GT11 is offline
97 blazer...cranks but won't start
Wants to crank. I notice when I turn the key switch on (not start) the gas gauge pegs out as if a super full tank and no fuel pump noise. At times, leading up to the crank but no start condition, I would turn the key on, hear the fuel pump and the gas gauge would indicate proper fuel level. When this happened, the vehicle ALWAYS started.
Here what I know now;
1. Fuel pump works. As indicated by the red auxellery jumper lead inside the engine well.
2. Good fuel pressure.
3. Starter checks good.
4. Battery hot and leads are cleaned.
5. Grounds in engine compartment and at fuel tank are cleaned.
6. Vehicle does have gas.
7. Air bag light stays on, even after pulling battery leads, letting set, and reinstalling.
This ABS light would come on and go off independently before the "crank but no start condition". So I'm assuming that the ABS might be its own problem; but not contributing to the crank but no start condition?
There were problems leading up to the no start condition. Vehicle began to become hard to start (but would start). After starting (at idle) if the gas pedal was pressed aggressively, the "service engine" light would flash on and off rapidly and the "ABS" light would come on. At this point the vehicle wanted to die. No appearent codes were given.
Now the "crank but no start condition".
Before this problem, the vehicle was sending the code for 3 o2 sensors. But a new fuel filter corrected this problem completely with no further appearent
problems. Then (about 4 weeks later) the "crank but no start". I do not think the fuel filter and the "crank but no start" problems are related.?
No other maintanance has been done to this vehicle that might cause this problem. At this point the manual I am using is useless...
Need your help guys.............
Thanks
GT
Old 03-19-2008, 09:05 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 97 blazer...cranks but won't start
97 is a bad year for ign switch problems.
On the air bag and ABS lights you will need a full abs/sir capable scanner to test.
What is you fuel pressure reading engine off engine craking cold and engine runnning?
The red is a prime test but not a direct power to fuel pump the connection to fuel pump can be lost in a bad punp relay
To test fuel pump find the gray power feed wire to the fuel pump and check for 12 volts when fuel pump should be running.
If no 12 volts jumper it with a 12 volt fuse jumper and check fuel pump pressure.
You need 60/66 lbs of fuel pressure.
63-65 lbs of prerssure on cold engine cranking to squirt the injectors.
The only true test on a fuel pump is to check the direct fuel pressure from fuel pump.
A quick test is to block off the return line and see if fuel pressure comes up to 75-85 lbs.
But do not run the pump at full pressure very long.
Also when testing fuel pump and pressure you need to tape a gauge to outside windshield or outside mirror and drive it on the road for 20 -30 minutes
until the pump gets has run a while to check for a pump fading out after hot.
Hard to start cold or hot and fuel pressure testing guide lines.
Check cold start fuel pressure.
Check engine running fuel pressure.
Check engine running on the road fuel pressure.
Then shut it off and watch for fast leak down.
Pinch off at rubber part or block off return line and check full pressure.
If pump has full pressure with return line blocked and low pressure without it blocked most usually the fuel pressure regulator is leaking or not holding pressure.
Later V6 and V8 gm engines should have 60-66 fuel pressure.
Cold start should be 64-65 lbs of pressure.
If you do not have full fuel pressure on a cold start the injectors will not squirt fuel.
Do not leave home without it.
Engine running should be 60-66 lbs pressure depending on engine load.
Full pressure with return pinched off should be 75-85 or more.
And if it has a fast leak down after shut off you have a leak in system.
Post back fuel pressure readings.
MT
Old 03-19-2008, 09:08 AM
theroadisalover theroadisalover is offline
Good fuel pressure? Would that be 60-66 pounds at least? Go to How to/technical sub-forum within the "Chevy Blazer" forum. Lots of good reading and troubleshooting info. Apparently, Chevy's Multi port sequential injection system which most likely resides in your intake, requires mucho pressuro all the time-o Road
Old 03-20-2008, 06:58 AM
Ok........I checked the fuel presure before and thought it was good. I will check a second time. If the fuel pressure is good what else could it be???
Yesterday I tapped on the interruptor switch (switch under the key switch). while cranking the engine. Thinking that maybe knocking off some corrosion on the tiny contacts in the switch box would help. No Go. Still cranks but will not start.
GT
Old 03-20-2008, 08:45 AM
MT-2500's Avatar
AF - Advisor
GT
Could and may be a thousand different things.
But needs proper testing at the time of no start to find out what it really is.
Give us your fuel pressure reading first.
MT
MT
Old 03-21-2008, 07:48 AM
Ok...... As said before. If the fuel pump comes on, the vehicle will start. When I crank the vehicle, and it does not start, the fuel pump does not come on. So,the only way for me to check operation of the pump and pressure is by powering up the pump by the red wire (jumper to the pump) in the engine well.
gt
Old 03-21-2008, 12:53 PM
old_master's Avatar
Advisor/Moderator
If the fuel gauge reads over full, it's an indication that the level sender in the tank has lost it's ground. The fuel pump and fuel level sender use the same ground. Follow the harness from the fuel pump module and check the ground connection, make sure it's clean and tight.
Old 03-22-2008, 07:36 AM
The ground for the fuel pump and sending unit are on the frame under the spare tire. That ground has been cleaned, retighten for a good metal to metal fit and greased. The problem still exists.
I do appreciate all the help.. But please keep sending suggestions. I'm presently working on a front end of a 94 GMC Jimmy 4x4 and this Blazer is my next project.
Thanks
GT
Old 03-22-2008, 09:20 AM
MT-2500's Avatar
AF - Advisor
Proper testing.
At time of no start check for good 12 volt power to fuel pump.
If power to it and good ground and pump no run check out pump and wiring plug in to it.
If pump runs check out fuel pressure.
If gauge pegs out at same time of no fuel pump run it points to ground or wiring.
For proper ground.
Check for voltage on ground wire.
And remember 97 is a bad year for ign switches.
Check all power feeds to and from ign switch.
Good Luck
MT
MT
Old 03-23-2008, 07:15 AM
I will check all the grounds. I know where the ground is above the spare tire and at the battery. Tell me where exactly the rest of the grounds are and I will gladly check them.
As wrote previously. I tapped on the Interruptor switch (located under the ignition switch on the column) while cranking the vehicle. No start. Thinking, by tapping on the switch it could knock some corrosion off of the contacts in the switch.
I did replace an Interrutor switch in this vehicle about 40k miles ago. It did fix the problem of total cut out while driving.
Thanks
GT
Old 03-24-2008, 07:44 AM
Any takers.............Let me know where all the grounds are located on my 97 Blazer so I can check them?
Thanks
GT
Old 03-24-2008, 09:01 AM
MT-2500's Avatar
AF - Advisor
That is a tall order.
Your best bet for a complete wiring diagram on power feeds and grounds can be found in a factory repair manual or the all data one year online repair info sub 24.95$ us plastic a year and 10 minutes set up time.
And you are set to go for a year.
http://www.alldata.com/products/diy/index.html
A good volt/ohm meter will test your grounds and power feed voltage.
Good luck
MT
MT
Old 03-24-2008, 06:23 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
gt
MT, Just like to add my 2 cents. It really sounds like he is having trouble with his ignition switch. I had my 96 blazer do the same thing with me. I ran a 12volt lead striaght to the fuel pump and it ran great. Traced the signal only to find that my ignition switch that I replaced 1 year ago was bad again. Replaced it and that was the end on that.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 03-24-2008, 07:03 PM
MT-2500's Avatar
AF - Advisor
Your 2 cents is welcome Gabe25 and.
Yes it could be the ign switch.
97 is a bad year for ign switchs.
MT
MT
Old 03-24-2008, 09:06 PM
Gabe25
I replaced the interruptor switch (switch below the key switch) about a year ago. The problem it was causing was a complete shut down of the vehicle while at hiway speeds. Then it would come back on and shut down again. I removed the interrutor switch and sure enough there was corrosion building up on the very small contacts in the switch. If I remember correctly, there were about 6-8 very small contacts in the switch box. I assume that the vibration from the vehicle moving would be enough to make contact and send power to the needed components. Powering up the vehicle again. I
have read that this "interruptor" switch has caused a multitude of weird problems. I would not be a bid surprised if the interruptor switch was again the root of my problems now. I have tried to knock on the switch thru the hole in the steering colunm in an attempt to free up the contacts. I did this while trying to start the vehicle. This however did not work. I do have an interruptor switch on hand but I want to look at all possible problems before doing the "just replace a part and see if it works" deal. I guess if there is a way of bypassing the interrutor switch and sending power down the line. If the vehicle starts then that would solve the problem.?. Wonder where you would put 12 volt in that colunm to check that?
Thanks
GT
