Old 03-19-2008, 04:56 AM
2000 AK 2000 AK is offline
HVAC: Air only comes from front vents....
Any ideas?
It's the 3 dial system from a 2000 1500 reg. cab. I tried hooking up the same style head control unit from my '02 Tahoe with no results (same part numbers, so they should be compatible).
Air only comes from mid level vents. No defrost, feet, or combination. A/C is functioning and unit does swtch to/from recirculate/outside as well. Just does not like any other position....
Old 03-19-2008, 08:47 AM
brcidd's Avatar
brcidd brcidd is offline
Re: HVAC: Air only comes from front vents....
Just a hunch- look above the gas pedal- is the arm to the diverter door still connected- I have found two or three lately that were not connected....the door will flop into its most convenient position.....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 03-19-2008, 11:59 AM
I'll check. Thanks.
Old 03-19-2008, 03:57 PM
777stickman 777stickman is offline
If you can't find the arm that brcidd described, look for this.
I'm pretty sure on your 2000 that the mode/diverter door is controlled by a small motor. The motor gets its signal electrically from the switch panel dial position.
This motor is located on the left side of the plenum right above the tranny hump. Look for 3 wires: White, Brown & Black. Pull the motor and see if it moves with the switch dial. Be sure the key is in the run position and the fan switch is in any position except off.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-19-2008, 06:19 PM
j cAT j cAT is offline
this is correct it is called the mode door actuator, it is usually a bad mode actuator motor, or the door is sticking ice,debris,,,,as stickman said remove from air box and if it don't move and there is voltage to motor thats it.....
this is a 5volt dc motor! not 12volts
