Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-18-2008, 09:45 PM
C_a_R_f_R_e_A_k's Avatar
C_a_R_f_R_e_A_k C_a_R_f_R_e_A_k is offline
Angry a sensible answer or a hammer
I have a 1985 honda prelude, I rebuilt the carbs when I got it and it ran great other then the fact that the choke doesn't work below +5 degrees, the problem I'm having is that all of a sudden the car had no go under load, I was lucky to hit 30km in 10 min, after some quick testing I discovered the ignitor was bad, it had a tec on it and the ignitor was only $75 but I discovered that the magnet was cracked and I went on the hunt for a distributor now the only one I found was a hitachi distributor and picked it up for cheap just to discover that the module/pick-up was in it but no tower or magnet, and then I found another one without the module/pick-up so I swapped the module/pick-up and low and behold it doesn't start, now if I advance the distributor past the factory slides it starts but its almost pointing to number 3, so i advanced the wires one spot and even tried backing them on slot basicaly the engines firing order is 1-3-4-2 and what i did was use the #3 tower as #1 and tried using #2 as #1 in another test and it just acts like its out of time, now I checked everything and all the timing marks are dead on and the distributor is pointing to number one, the fuel pump has good flow and 3 psi pressure and theres spark and there is fuel getting to the engine, anyone have any other ideas????
Old 03-19-2008, 08:48 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: a sensible answer or a hammer
did the timing belt jump teeth?
Old 03-19-2008, 08:54 AM
450HP 450HP is offline
Are you sure that you don't have the dizzy 180* out?
Scott
Wide open till you see God... then brake!
Old 03-19-2008, 11:34 PM
the distributor only goes in one way and the timing belt has not jumped, I put the bottom end at complete TDC and the cam is dead on also the distributor points straight at number 1, there is 135psi compression straight across all 4 cylinders, I also checked to see if the cam slipped inside the gear and it hasn't
Old 03-22-2008, 12:37 AM
slideways...'s Avatar
slideways... slideways... is offline
135 seems low to me. but i could be wrong. anyways what is your manifold vacuum? and are you sure its an engine issue? if so, read your plugs.
wait a sec, you said you had a tec dizzy originally and put in a hitachi unit after? are you sure they have the same orientation? seems like maybe thats your problem...
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 03-22-2008, 01:34 PM
The tec distributor and the hitatchi both have the same orientation, honda used either or in that year, 135 compression is remarkable to have in a car with 340000 kms on it and I can't read the intake vacum because its not running and I can't any vacum leaks, it tries to start but thats where it stops
Old 03-26-2008, 11:56 PM
I finaly fixed it, I found another hitatchi distributor out of an 85 accord. After I got it going I blew a fuse and the charge light never came on to tell me that the battery was dieing so there wasn't enough juice to crank the engine over and I ran over my foot when push starting it
Old 03-27-2008, 05:48 AM
Kind of a Big Deal
glad you fixed it.
