Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-18-2008, 07:51 PM
98spyderman 98spyderman is offline
Turbo question
hello to all i have a 1998 eclipse spyder with a 2.4L i was over at a friends house and noticed that the exhaust manifolds for his GST fit were my headers go. now this is my question if i do decide to turbo it with an intercooler what is a safe pounds of boost to run with stock internals? thanks for all the help and on a side note if i turbo it how much faster would that make it
Old 03-18-2008, 08:20 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Turbo question
Welcome to AF!
Im not really sure on how much boost the 4g64 motor will take. VG runs about 8-10psi I beleive with no problems. It will be a lot faster. Make sure you know what your getting into. Turboing a car is a lot of work and requires a good bit of knowledge to make everything work correctly. Do your research and you should be fine.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-18-2008, 11:48 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: Turbo question
Ive been running about 9 psi on mine with a 14b with no problems. And yes, turbo with supporting mods on your car, will make it alooot faster.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 03-18-2008, 11:49 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Turbo question
Yeah dude, talk to vanillagorilla about that. SilvrEclipse turbo'd a 420a and I am sure he can be of help too. I'd for sure leave it at the WG spring pressure though, I wouldnt go more than 8 psi.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-19-2008, 12:00 AM
Re: Turbo question
Yeah but in order to run low boost your going to have to rely on something more than the factory internal wastegate. I tried running mine on internal wastegate and it would want to boost to like 13psi, so thats why I'm currently converting to External wastegate. Im running a Tial 38mm external wastegate with an 8psi spring.
Caleb
vanilla gorilla
Old 03-19-2008, 01:03 AM
new2mitsu new2mitsu is offline
Re: Turbo question
i ran 6=7 lbs on my 420A with 450ccs and a 190 lph... no problem. ive heared u can get about 8-9lbs outa a 4g63 with jus fuel system...
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 03-19-2008, 02:09 AM
Thor06's Avatar
Jizzed In My Pants
Re: Turbo question
You should be able to get ahold of like a 5 psi spring... and IIRC they arent expensive or hard to change.
Old 03-19-2008, 09:53 AM
Holset powered 420a
Re: Turbo question
Yea I didn't have much luck with an internal wastegate either. It ended up costing me the motor. It either wouldn't shut all the way or it wouldn't open much
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 03-23-2008, 01:12 PM
Re: Turbo question
what is going on i like the fact that i can turbo my car on stock interals i think that is what i am going to to thanks alot
Old 03-23-2008, 01:58 PM
Holset powered 420a
Re: Turbo question
Good luck with the process. I would actually like to see a turbo build thread in the project section with pics of the whole process.
98 Eclipse GS Turbo
2001 BMW 325i - DD
