Old 03-18-2008, 06:17 PM
79403ta 79403ta is offline
brake pedal problems
1997 chevy truck Z71 350 and a 4l60e when i push my brake pedal i get a clicking sound comming from above the steering coloumn (this is with me in the floorboard looking up while pressing the pedal with my hand) the weird thing is it only does it comming out of park...so after a little while messing with it i can take the plastic box off of the brake pedal rod which bypasses having to push the brake to get it out of park and it doesnt make the noise when i do this...any ideas will be well appreciated
Old 03-19-2008, 03:57 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: brake pedal problems
It's probably the shift-lock mechanism... if it doesn't do it with that removed there's not really anything else it could be. I notice a click on most GM vehicles when taking them out of park... I think it's probably normal, it's never caused a problem anyway. If it's a concern to you, replace it.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-19-2008, 08:38 PM
thats what i was thinking too i appreciate it..it sounds like dropping a marble on concrete only when you push the pedal in park...but i will replace anyways thanks again
