Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 10-15-2001, 10:25 PM
Hrtbrker42 Hrtbrker42 is offline
Thumbs up LED Washer lights
I just got my LED washer lights installed on my Max. I just want to know if anybody knows how I can re-wire them so when I push the remote to unlock the car and the dome light turns on inside my new washers can also turn on, well when I push that button I want the lights to turn on at the same time. And i also want to have a manual switch I can have inside the car to turn them off and on whenever I want. Can either of those two be done if not both. Thanks.
Old 10-16-2001, 12:17 AM
Nizmolee Nizmolee is offline
Send a message via AIM to Nizmolee
i dont think its possible to have both ways. first to have the LED work with your stock alarm, you have to find a non constant power, you can find this wire behind the gauges, as you tap into the wires with a battery tester. to find this you need a battery test light, and find it.. hard to explain..on the other hand, for a switch, use a constant power... normally a switch will have aCC, power and ground. make sure you connect the ground wire last! or you may blow a fuse.. thats the way!! good luck!
98 Auto NOS Maxima.
