Old 03-18-2008, 05:24 PM
freekie freekie is offline
92 Lesabre Starting issues. Thinks its VATS
Morning,
I have a 92 Lesabre that will not crank the starter with the key. I can jump the starter from under the hood with a screw driver and the engine will start then die if the ignition is in the on position. I believe it to be the VATS thats causing me problems.
So question:
With the key in the on position should the Security light blink or go out?
Does my problem sound VATS related?
Old 03-18-2008, 05:33 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 92 Lesabre Starting issues. Thinks its VATS
If the security is blinking, you have a problem with the security system. Do you have a spare key to try, or have you tried cleaning the resistor pellet in your existing key?
Old 03-19-2008, 08:07 AM
brcidd's Avatar
brcidd brcidd is offline
I agree with the above- if you want to permanently bypass the VATS syste- never to see that ugly security light again- it can be as simple as soldering in a resistor that matches the one in your key-- I have done a handful this way...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 03-21-2008, 09:48 PM
spinne1 spinne1 is offline
I would first suspect the transaxle position switch (the part that controls the car starting in only park or neutral.) I would suspect this before VATS. Nevertheless, it could be VATS. Bypass that puppy by soldering a resistor and then see if it works. If not, properly diagnose it with a good manual (GM or alldata.com.)
Old 03-22-2008, 08:09 AM
It was the VATS. I put the resistor across the 2 white wires under the dash and the security light went solid and the car started.
Thanks
