Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 03-18-2008, 04:43 PM
jv117v2 jv117v2 is offline
clutch squeak
i just replaced my clutch and when i engage the clutch it squeals very loud. i hear it could be the disk and the throw out bearing. i called mechanics and keep getting mixed answers. can anyone help???
Old 03-18-2008, 05:03 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: clutch squeak
i'm thinking TOB. either way, you are going to have to pull it back apart. sorry to hear that.
Don't act like you don't love it.
503/2000
Old 03-18-2008, 08:06 PM
Re: clutch squeak
damn! could it be the master or slave cylinder? could not be pushing the fluid enough so that the fork isnt getting pushed all the way in?
Old 03-18-2008, 09:33 PM
Sleepr awd's Avatar
Re: clutch squeak
the squeeling you are referring to is most likely caused by a part that is rotating. Since the clutch, when actuated and moving the fork to push the TOB away from the pressure plate to free the transmission from rotation, it would make sense if it was on either side of the TOB being the pressure plate, or the TOB, or the clutch fork. I don't see how a master or slave could cause that problem, seeing as how they are hydraulic driven and wouldn't produce enough friction to cause a sound like that.
You did replace the TOB with an OEM unit, not an aftermarket unit correct?
If it were teh disc that was squeeling (which it will smell like burn fried shrimp if it were) it would go away very shortly since it operates similarly to brake pads, unless it was constantly being actuated, which it sounds like it is going in and out sorta fine.
who exactly replaced the clutch? was it solely You or did you have a friend help, or what? Which brand of clutch kit did you go with? I did the clutch on the Galant, and barring not getting it lined up right (which if the trans went on, its lined up right) there isn't too much to mess up.
I say, pull it back out. There isn't too much you can do about it from the outside.
503/2000
Old 03-19-2008, 02:57 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: clutch squeak
it should go away...mine did the same thing when i replaced my clutch, and about 30 miles or so later it went away (about 400 miles or so later the TOB started to rattle again...whatever).
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 03-21-2008, 02:36 AM
Re: clutch squeak
im glad to hear your yours did the same thing. is it stiil working fine? my hardly does it now, only when i down shift and the rpms are up a little bit and when i start it. i just hope it doesnt just stops an fuk up, cuz i had false hope.....i used an oem exedy clutch kit for now till i get more power.
Old 03-21-2008, 09:36 AM
Sleepr awd's Avatar
Re: clutch squeak
thais the same kit that I put in the eclipse. !!!! Too funny. Seriously though I've got 33000 miles and no issues with that kit. Just taking it east on the pressure plate and it all seems to be fine.
503/2000
