Old 03-18-2008, 04:08 PM
beast91RS beast91RS is offline
Send a message via AIM to beast91RS Send a message via Yahoo to beast91RS
Thumbs down '99 GA Rack & Pinion Mounting
Rack and pinion has somehow broken loose from mounting locations on engine cradle. Both brackets have broken completely away. When you turn the wheel, the whole rack moves at least within 4 inches or greater in either direction. This puts a lot of slack in the steering.
Short of welding this thing in place, what is the best idea to correct this problem.
This vehicle isn't exactly the safest thing in the world to drive when the steering doesn't go where you need it to when you want it to.
Any information or ideas would be greatly appreciated.
Thanks in advance.
1991 Camaro RS - 3.1 V6
Shaved body kit, 25th anniversary edition rims, shaved marker lights, 8 point roll cage and soon to come 350 swap. She's a work in progress.
Old 03-18-2008, 10:38 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: '99 GA Rack & Pinion Mounting
should be able to replace the brackets , if the rack isnt broke or damaged from the play in the steering gear...
Good Luck
1999 Grand Am SS 3.4 OHV
Old 03-19-2008, 06:19 AM
I guess it could be possible to replace the brackets. If so, that would make it much easier. Looked to me like the mounting locations were made into the engine cradle, however.
Old 03-20-2008, 07:01 PM
one side of the brackets faces forward, and the other faces backwards.
The R&P has to pull out through the drivers side wheel well, a pita but do-able DIY.
