Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-18-2008, 03:41 PM
scottyboost scottyboost is offline
Fuel pressure regulator leaked once
1997 3100 Cutlass
Smelled raw fuel. Shut car down. Popped hood. FPR was wet with fuel on outside. By the time I found a light to investigate, the fuel was dry and I can't get it to leak again. I pulled the vac line to check and no leak there - engine running. Should I replace the FPR, or just the o-ring/gasket? How can it leak once?
Old 03-18-2008, 07:18 PM
maxwedge maxwedge is offline
A990 racer
Re: Fuel pressure regulator leaked once
Welcome to AF, get a pressure gage on the rail check for pressure leak down after shutting off, should drop very slowly, either way I'd replace the seal and the reg, dangerous condition any fuel leak.
