Old 03-18-2008, 03:33 PM
quadtrac quadtrac is offline
Orange or Green antifreeze
I have a 2000 Grand am and it has the orange "Dex cool" antifreeze in it. Many people have told me to flush that stuff out and run the regular green antifreeze. They said it will eat the gaskets out eventually. What is the best antifreeze that I should use. Thanks
Old 03-18-2008, 04:30 PM
Andrew Martin Andrew Martin is offline
Re: Orange or Green antifreeze
Not quite true. I've seen people try to use orange antifreeze in other vehicles and they wondered why it ate their gaskets away. Apparently, they never saw the "Designed for GM Vehicles" badge on the jugs.
You have a fairly recent GM product; using GM Dexcool antifreeze will prolong cooling system component life and improve its efficiency. The green antifreeze is just generalised for "All makes and models" and doesn't fit any one make in particular. Think of the green antifreeze as a "jack of all trades" and the orange antifreeze as a "master of one".
Dexcool antifreeze is the best antifreeze you can use in a more recent GM vehicle.
2000 Ford Taurus SE
Ethanol FFV
3.0 Vulcan, AX4Shit
Old 03-18-2008, 04:41 PM
J-Ri's Avatar
J-Ri J-Ri is offline
The orange Dex-cool is supposedly "fixed"... the original pink Dex-cool had lots of problems. In my experience, the orange isn't much better. It still eats away at aluminum and gaskets, but doesn't sludge up like the pink did.
I personally reccomend using non-silicated universal coolant. Silicated coolants can (supposedly) damage aluminum parts not designed for it. My '96 Beretta (designed for Dex-cool) has had green silicated (basically VERY fine sand) coolant in it since ~'98 with no problems.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-18-2008, 04:50 PM
That's interesting. =S I've used Dexcool antifreeze in all four of my GM vehicles and never had any problem with it whatsoever.
But he's ASE certified and I'm not. =D
2000 Ford Taurus SE
Ethanol FFV
3.0 Vulcan, AX4Shit
Old 03-18-2008, 04:59 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Yeah its realy personal prefferance on the coolant.
Gm does recomend using Dex, though you dont have to.
My Se uses Dex and its only 1 year old and is already looking terrible! My GT has the old green and is looking fine after 2years.
The newest Coolant by Preston, a yello colored fluid, mixes with all coolants.
I dont recomend mixing any green with Dex it'll turn to sludge in no time and clog things up(heater core, radiator).
ps- thier are several ASE techs here at AF, myself included.
1999 Grand Am SS 3.4 OHV
Old 03-18-2008, 05:50 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
I've used DexCool in 5 of mine without major problems, ( one intake gasket replaced in a 3.4 but that was poor design/materials.) Whatevercoolant you decide to use, make sure it meets the specifications of GM . If your vehicle is under warranty, you can void it by using something not compatible. DexCool is an Organic Acid Technology coolant with a different protection package than the old standby ethylene glycol coolant we all used years ago. Your engine isn't fully protected if you aren't using something that meets the minimum specifications set forth by the vehicle manufacturer.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 03-18-2008, 05:58 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
GM used to have issues with inferior quality gaskets but like said earlier they have been corrected, mid to late ninetees models with dexcool often had gasket and coolant issues. The failed gasket areas would leak and air contacted the coolant around the leak and formed a nasty crystalized slimy coating on the interior of the component (usually an upper intake).
Decool itself is better for todays engines that utilize aluminum in the cooling sytem and engine.
Main problem with the dexcool crystalizing or forming gel is when the coolant comes in contact with outside air, this only happens when you have a minor coolant leak that lets air into the system. A closed and pressurized system that is regulary maintained will be just fine with dexcool.
Old 03-18-2008, 06:36 PM
Thanks, I forgot to mention that also. A problem with air infiltrating some cooling systems and causing issues has been traced to faulty radiator caps. The fix was to replace it with a Stant brand cap.
Old 03-18-2008, 07:07 PM
Radiator caps, or coolant reservoir caps? 96-98 N-bodies I know don't have direct access to the radiator, just a reservoir with a plastic cap.
2000 Ford Taurus SE
Ethanol FFV
3.0 Vulcan, AX4Shit
Old 03-18-2008, 10:21 PM
I've seen stealerships use green coolant when a vehicle was under warranty.
The newest coolants available are the best to use, most all allow for a wider temperature range adding more protection.
The 99+ N-bodies are the same, no radiator cap, just the reservoir cap. You can buy replacement rad. with a cap pricey tho.
Old 03-18-2008, 11:04 PM
I should have been a little more clear on this. Some vehicles that have radiator caps have experienced a problem with them in where the seal breaks down and allows air into the cooling system. Not all GM vehicles have radiator caps(closed systems) and not all have experienced this issue.So it will not apply to all vehicles.
