Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 03-18-2008, 10:22 AM
geo69x2 geo69x2 is offline
283 Burning up coils
I have a 67 Impala with a 283 which I had rebuilt and changed over to electronic ignition about a year and a half ago. The only problem I am having is that it has burnt up two coils within 2k miles. What is causing this and will a high performance coil solve the problem.
Thanks
Old 03-18-2008, 10:31 AM
450HP 450HP is offline
Re: 283 Burning up coils
Define "electronic ignition"... meaning was a Pertronix unit installed, or did you upgrade to an HEI, switch to a MSD setup, or ???
Scott
Wide open till you see God... then brake!
Old 03-18-2008, 11:09 AM
It was converted to an HEI system.
Old 03-18-2008, 12:06 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Did you replace the ballast resistor wire with straight, 10-gauge wire all the way to the fuse panel? If not, this is something you want to do. The HEI system uses no ballast resistor or wire at all - coil gets full voltage.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 03-18-2008, 12:10 PM
Thanks silicon212! That's where I was heading with my question!
Scott
Old 03-18-2008, 12:14 PM
I'm not 100% sure about that. It does have a second wire run to the red coil wire. However I'm not sure of the guage or origin of the wire. I with have to check that out when I get home. Thanks for the heads up. I'm not really a motorhead and I'm learning as I go on this one. Again thanks for the help.
Geo
Old 03-18-2008, 12:16 PM
Do you have a volt meter of any sorts?
Need to make sure there's a full 12V at the dizzy.
Scott
Old 03-18-2008, 12:31 PM
I do have a volt meter I just need to Know where to check the voltage.
Thanks
Geo
Old 03-18-2008, 03:20 PM
Here's a link to take a look at... hopefully it will clarify things a bit.
http://rmcavoy.freeshell.org/HEI.html
Scott
Old 03-18-2008, 08:22 PM
Scott
Scott thanks for the link, the voltage regulator never crossed my mind. I will change the resistor wire to 10 guage and the voltage regulator. You help has been invaluable.
Thanks
Geo
