Old 03-17-2008, 06:28 PM
Doranpalmer's Avatar
Doranpalmer Doranpalmer is offline
Dist. cap and rotor
Okay maybe I'm just retarded or something, but with as many rotors as I've changed out, I still can't find any screws to hold this rotor on, and I can't pull or pry on it enough to make it come off. Any ideas on how to remove a rotor from the dist. shaft? Can I really pry on that sucker without damaging the shaft?
Truck had three wires barely connected, and the cap and rotor are horribly corroded, yet it still runs great, amazing. BTW - whoever posted the how-to for dropping the steering stabilizer or damper, that was brilliant, easiest way to go. Oh and another three plugs were less than hand tight, wow.
Right now I have new everything with an old rotor so I can get to work, so while any help is appreciated, quick help would be really great. Thanks.
1991 Chevrolet S-10 Blazer
1984 Chevy C20 Silverado - 350 5.7l
You a Cowboys Fan? Check out CowboysNation.net
Old 03-17-2008, 07:05 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Dist. cap and rotor
Yup, it pulls straight up and it's on tight...you got any old school 600grit?
Old 03-17-2008, 08:09 PM
No but I got some new school 1500 grit, will that work?
I'm gonna get at it in a few minutes, I don't suppose any lubricants would help any? Drives me nuts just knowing that corroded P.O.S. is still on there. Thanks.
Old 03-17-2008, 09:20 PM
Alright, it wasn't pretty, but it's done and the truck runs ten times better just from that. Hit the gas and it jumps with power, lot different than the beater ford escort I've been driving for two years.
Old 03-18-2008, 07:04 PM
AF - Advisor
You kept the Escort didn't you? It'll get half again better fuel milage.
Old 03-19-2008, 02:28 AM
Actually I'm trying to sell it, need a vehicle for work(just to and from) and the escort has a bad water pump again, considering I've replaced that before on that car two years ago, I'm not totally interested in doing it again.
I gotta ask for clarification though, what was "It'll get half again better fuel milage." supposed to say? I got the jist that it would get better mileage than the blazer, just making sure it wasn't a code or something Cause I missed it the first time around
Old 03-19-2008, 05:22 PM
AF - Advisor
It'll get the fuel mileage of the Blazer + half the mileage of the Blazer....about 20 + about 10...about 30 mpg.
Old 03-19-2008, 09:37 PM
Yeah okay, that it will with a tune up
