Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 03-17-2008, 05:13 PM
AmysTrooper's Avatar
AmysTrooper AmysTrooper is offline
98 trooper coolant leak
98 trooper with 3.5 had I replaced the waterpump and timing belt about 30,000 miles ago. I had the starter go bad and replaced that and noticed a coolant leak. Hoses good (also replaced) do you think that water pump is bad already or should I just open it back up and take a peak?? Im not sure what else might be leaking if its comming from under the front motor cover, which that what it looks like.
Old 03-17-2008, 06:14 PM
boritz's Avatar
boritz boritz is offline
Re: 98 trooper coolant leak
Coolant coming from front cover is highly likely to be either the water pump seal or gasket.
Old 04-30-2008, 07:47 AM
Thanks for reply, this hasnt leaked for a while now, I think the oil change place may have overfilled something but I am not sure. I usually do my own oil changes but when cold I will take it in. Thats my guess right now. Thanks again
