454 Big Block Question
Hello all,
I have a big block that I just recently broke down and on the front were you have your timeing chain and what not there is a marking on the block that has a big E on the left and then soemthing that says SS Perf and under it the number 10. What does that mean if anything at all? Thanks, Cole |
Re: 454 Big Block Question
is it the stock engine, and wat is the engine in?
Well, It is a engine that was pulled out of what i was told a suburban.
But I just didnt know if the markings made any diffrence about the block. Someone told me it was an LS6 block and some others told me it didnt matter so thats all. Thanks For Your Help, Cole |
Those are foundry marks. Virtually all "short deck" Mark IVs (through '92 or 3) BBCs have a Hi-Perf/Pass cast into them somewhere. An LS-6 is a 4-bolt main block with a forged steel crankshaft. Not found in Suburban as original. That's the 450 HP version, found in '70 and '71, mostly Chevelles, but I've seen them in Corvette and Camaro as well.
LS-6 was also equipped with rectangular port heads, exclusively. Jim |
)and the '71 Chevelle LS-6 was the "little" 425 hp.
I was always under the impression it was LS-7 that was "under rated" at 460 HP, with the 12:1 compression and the big solid cam. Liie ZL-1, 500 or 550 was more accurate. LS-6 was rated at 450 and based on how many my 366 HP GTO beat, I wouldn't say it was under rated. The Ram Air III WAS under rated about 30 HP, but I would think the big Chevy would have an edge if it were more than 20 or 30 HP "bigger". The Pontiac always made up for it with bottom-end torque, which all rectangular port BBCs are hurting for. I got better runs in street "trim" from the 390 and 400 HP 427s.
Jim |
Ysardogg PS Some Great legendary dealer's put in anything your little heart desired. |
MrPbody Come down to San Clemente and I'll help you out with big words and show how stylish the rear bumper is on my STOCK 71 SS 454 LS-5 not 6 convertible M22 4 speed fac. air, Or my up and comming built 71. I have a lot of friends with GTO'S and TA'S there great. My friend Lars is just replacing his Ram Air IV with a nice 455 (why? beacuse he can) that will be fun. I'm shure your Goat is nice but remember to pass a Chevelle like you claim the Chevelle it has to be going in the same direction. I fly Helicopters and I think I've seen Mr Peabody in his "Little Flying Saucer" (Ram Hot Air-1) Just funnin.. |
i have a 454 motor that is disaling and back firing can anybody help please, i had the carb rebulit put new plugs and wires and timed it at 6 degrees
Yardog,
I think you missed something in my post that's rather significant... I was talking about my street racing experience in the early 1970s... Not current. I don't own a GTO anymore (wish I DID!). Lars could have done a lot better than a 455. We (most Pontiac "builders") don't use them anymore. A 400 block with a current "stroer" kit is far "tougher" and makes the same or a little better power. Chevybuel, Are you sure the distributor is in correctly? What is the compression ratio? You could have a multitude of issues. Start at the beginning, and go "by the book", setting the dwell, timing and idle speed. Report back. Jim |
