Old 03-17-2008, 02:55 PM
agelism2 agelism2 is offline
04 alero oxygen sensor
I need to replace the upstream oxygen sensor (on the engine). Does anyone know where it is located?
It is a 4 cylinder engine
Old 03-17-2008, 05:21 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 04 alero oxygen sensor
Welcome to AF.
It would help to post what engine you have so members can be accurate in their replies.
Timeslip 08/12/06
AF Community Guidelines
Old 03-17-2008, 09:02 PM
BNaylor's Avatar
On the 2.2L Ecotec engine the sensor is located on the driver's side of the exhaust manifold. You have to remove the exhaust heat shield to see it and/or to test/replace.
Timeslip 08/12/06
Old 03-20-2008, 05:46 PM
scoopy03 scoopy03 is offline
its really easy to do just take the 10mm bolts off for the heat shield. you a oxygen sensor socket (its only like $8 from autozone just ask for it). unplug the sensor take old one out put new one in. you can either disconnect the battery for 3 hours or just drive it and it will go away.
99 olds alero 2.4 DD
92 notchback with 460 carb'ed
