Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 03-16-2008, 02:03 PM
zach_rupe zach_rupe is offline
I need some help!!!
I have a 1992 Chevy Lumina APV that won't start. It will crank but it won't turn over. What do I do? I was told that there was a relay switch for the fuel system but I can not find it. I have changed the spark plugs recently and the starter about a month ago. This is the only vehicle I have and I need to get it running as soon as possible. The problem started with the van "puttering" when accelerating and when idling it would die. Then one final time it died and hasn't restarted since. Any suggestions?
Old 03-17-2008, 03:43 AM
ontariodave ontariodave is offline
Re: I need some help!!!
it is your fuel pump.it happen to my van this year
Old 03-17-2008, 05:10 AM
LMP's Avatar
LMP LMP is offline
what engine type?
pull a plug wire and check if you have spark?
is the Check Engine Light ON? IF yes pull the codes
www.avigex.ca/xport/readingcodes.jpg
before pulling fuel tank, better first check fuelpressure at fuel rail (3.8 40 psi 3.1 12 psi)
ignition module and crank sensor (3.8) are common type of failures at that age.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 03-17-2008, 02:12 PM
how do i go about checking all of those things. It is a 3.1.
Old 03-17-2008, 02:46 PM
LMP's Avatar
LMP LMP is offline
Checking for spark is easiest. Just pull the plug from a spark plug, then connect a spare (or remove one) spark plug , let it rest on a metal part of engine or body and let someone start and look plug for spark.
YOU did not tell if the Check Engine Light was ON....if yes, connect A and B
with a paper clip, turn key ON and count light flshes as explained above.
Once this is done, report results
Old 03-21-2008, 01:36 AM
i got it running finally...i had to change the dist cap and rotor button...thanks all for your assistace and such
