Old 03-16-2008, 01:34 PM
school school is offline
OLDS bravada no power
i have a 1994 olsmobile bravada and when i floor it at a dead stop it doesnt move like it should, but when i am going 30 to 40 and floor it it has power.....whats wrong with it.
Old 03-16-2008, 01:48 PM
old_master's Avatar
Advisor/Moderator
Re: OLDS bravada no power
What have you checked so far?
Old 03-16-2008, 03:54 PM
We replaced the fuel pump and the main computer. we are being told the #5 cylinder is mis-firing and because it is a "spider" we will have to replace the whole thing.
Old 03-16-2008, 03:56 PM
old_master's Avatar
Advisor/Moderator
Before you spend any more money on the vehicle, I would suggest checking the fuel pressure and leakdown rate. The ECM (Electronic Control Module) is a very substantial piece and rarely needs replacement. Most of the time, it is replaced due to a technician not following the diagnostic flow charts correctly.
Old 03-16-2008, 04:12 PM
How do we check the fuel pressure and leakdown rate?
Old 03-16-2008, 04:17 PM
old_master's Avatar
Advisor/Moderator
There is a service port on the fuel pressure line very close to the distributor. Key on, engine off, pump running, pressure must be 60psi to 66psi. Pressure must remain above 55psi for 3 to 5 minutes after the pump shuts off. Check your AF inbox.
Old 03-16-2008, 04:53 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Here's the service port,
Fuel pressure test kits are available at most auro parts stores and Harbor Freight.
