Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-15-2008, 08:27 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
CRX stumbles
I have an '88 CRX Si, when I first start it up it seems to stumble (like a misfire thru the exhaust), it runs a lot better once it's warmed up though. I changed 3 of the spark plugs but couldn't get the socket into the fourth hole. It seems a little better now. Could this be from old or bad gas ?
Old 03-22-2008, 12:48 AM
slideways...'s Avatar
slideways... slideways... is offline
Re: CRX stumbles
could be bad gas, could be many other things. sounds like either too much fuel for the ignition to handle on a cold start, or maybe other things like a bit too much oil from bad rings or valve seals. could be a tune up issue, fuel injector issue, or whatever. how did the plugs look? best way to tell if your rich or lean is reading plugs.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
