Old 03-15-2008, 06:58 PM
superman11167 superman11167 is offline
98 escort zx2 cps problems car will not start
i took out my new cps an the tip of it was broke off, what could do that it was put in correctly
Old 03-15-2008, 10:16 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: 98 escort zx2
Well... the car shouldn't start without the sensor on there.
Was there anything else done or was this a simple matter of taking the old sensor off and putting the new one in its place?
And I do have to ask... did you remember to plug it in (securely) after you replaced it?
Old 03-15-2008, 11:25 PM
Re: 98 escort zx2
the cps is plugged in an i checked the wires. what could have went wrong in that short of time i really dont know
Old 03-15-2008, 11:28 PM
Re: 98 escort zx2
what do you think i should check out
Old 03-16-2008, 01:56 AM
tripletdaddy tripletdaddy is offline
Re: 98 escort zx2
I think you should have your buddy check out.......checked out.....
Assuming all else is fine, I would make some sort of attempt to reset your PCM, as that is what the CPS/CKP is connected to. All I can suggest is to remove the battery cable for awhile to let it clear itself and try starting it later. See if Ford can tell you if there is a way to reset the PCM. Also check all of your fuses, wiring to the PCM. Dunno.
I suggest keeping your buddies away from your car and keys.
