Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-15-2008, 06:09 PM
Breadman52 Breadman52 is offline
OOPS!!! on me
HELPPPP!! HELPPPPPPP!!!
I did a boo boo. I have a 2002 Camry. After a bit of research I decided to troubleshoot the reason my "check engine" light was on but made one mistake. After connecting a jumper wire from terminal 4 to terminal 15 on the diagnostic connector under the dash I started the engine!! The check engine light is gone but now the engine doesn't idle correctly and it dies if left for a few seconds. What component/sensor do you think I burned up or at least make dis-functional. Thanks, Bruce B.
Old 03-15-2008, 07:20 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: OOPS!!! on me
I think there is a very good chance you destroyed part of your ECM. I would start trying to find a used ECM from an identical car somewhere and replace the one you have.
Next time, use a code reader to troubleshoot your trouble codes.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 03-16-2008, 04:26 PM
Mike Gerber Mike Gerber is online now
AF -Advisor
Re: OOPS!!! on me
I have to agree with Brian. Your car is OBD2, as all cars have been since model year 1996. You can not pull the codes with a jumper wire on OBD2 cars as you could on OBD1 cars.
If you do wind up needing a new ECU and can't find one locally, try Taprecycling.com. They are a Toyota salvage yard located in Texas.
Mike
