Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 03-15-2008, 12:38 PM
2005LSdude 2005LSdude is offline
Oh Crap! A/C don't work!
I just know this is gonna be expensive, but it got a little warm yesterday so I tryed useing AC and no cold, had both sides of dual turned all the way down, blows hot air out the right side center vent and slightly cool to warm air on left side of center vent. I can hear compressor kick on (if I turn down fan speed), checked the fuses, there is a relay that has something to do with ac (of course can't tell if a relay is bad by looking at it) but all fuses ok. Now the paranoid part of me is saying the dealer messed with something, I got my car in with a check engine light just before bumper to bumper warranty ran out (just 3 miles left) and they changed a o2 sensor, but when I picked up the car and started it I seen someone had AC on when it was to cool to have needed it. Where they a little pissey that I got that work done for free and screwed with my AC somehow? Is there something to check for? before I take it in (and not to that dealer again).. Shorod? anybody? help!
Old 03-15-2008, 01:08 PM
inafogg inafogg is offline
Re: Oh Crap! A/C don't work!
if compressor is working you'll have to put a set of guages on to see what the readings are.it sounds like its got a low charge of freon.
Old 03-15-2008, 02:58 PM
danielsatur danielsatur is offline
Is this a 2005 Lincoln LS?
Is this car still coverd by Ford?,I would take it back and give them Hell anyways.
All of the problems should of been weeded out of this car by now.
LS= LINCOLN SERVICE
They rape people on this service.
Old 03-15-2008, 05:37 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
You should first try the reset procedure on the Dual Automatic Climate Control (DATC) unit. Search the forum, but I think the procedure is the press the Auto and Panel buttons at the same time, release and press the defrost button within 2 seconds. All display segments will light and if there are any diagnostic codes, they will be displayed. If no codes displayed, then press the defrost button (I think) and it will reset the DATC.
If that has no effect, then I'm afraid you probably have a faulty Dual Coolant Control Valve (DCCV). The part isn't too bad to replace, but the part isn't cheap, even from www.fastpartsnetwork.com. Again, quite a few threads on the DCCV, search the forum. I'm sure there's one with steps or a link to the steps to replace the DCCV.
-Rod
Old 03-15-2008, 08:58 PM
LS= LINCOLN SERVICE
I've heard with other bumper to bumper warranty that even 1 mile over and you gotta pay, so I'm not even gonna try, I have 50,300 something...
Old 03-15-2008, 09:02 PM
I'll try that Shorod and see if it works, I'll let you know later. Thanx for the advise. Oh and yes it's a '05 V6 .....
Old 03-15-2008, 09:41 PM
As long as you got a good driving record and good credit it might be
worth it to buy something new just for the insurance.
Parts + service is to high to pay out of pocket.
Turn a Neg into pos.
Sell your car to carmax,and put money into your pocket.
don't tell your wife!
Go to NADA web site and tell them what you want,the local dealers
will give you best price.
Take advantage of REBATE's,and Low interest finacing.
Don't put [stuff] down,go out on a date in your new car.
Make sure they fill the tank + free oil changes.
Trust me !
PS. Don't buy a LINCOLN LS.
Old 03-15-2008, 10:43 PM
shorod's Avatar
SHO No Mo
I looked up the procedure, what I typed from memory earlier was not correct. Try the following (from Alldata):
The DATC module self-test through the front panel display:
  • can be initiated at any time. Normal operation of the system stops when the self-test is activated.
  • is entered by pressing the OFF and FLOOR buttons simultaneously and then pressing the AUTO button within two seconds . Record all DTCs displayed.
  • concludes by reporting all on-demand DTCs. Follow the diagnostics procedure given under ACTION in the DTC index for each DTC given.
  • reports individual on-demand DTCs as four-digit DTCs (less the alpha character).
  • will calibrate all the mode doors and check all analog inputs. The DATC module will only report on-demand (hard) faults that occurred while the DATC module was conducting its self-test.
  • will light all control panel display segments if no faults are detected.
  • will report individual on-demand DTCs without the °C symbol lit.
To exit the self-test, press the defrost button. This will clear all on-demand codes from the DATC module memory. If no button is pushed, DTCs will continue to be displayed.
-Rod
Old 03-15-2008, 11:25 PM
Ok, thanx for update, haven't tryed it yet, will tomorrow....
Old 03-16-2008, 10:28 AM
-Rod
Showrod, nothing happens except when I press auto it just functions like normal, no displays, Is the engine suppose to be running or off with key switch on? and what does it mean floor buttons? I press off and the 3 buttons that's for floor air flow direction, hope you dont mean all buttons (I dont have that many fingers)...
Old 03-16-2008, 10:20 PM
shorod's Avatar
SHO No Mo
You'll need to have the key in the Run position. I don't think the engine has to be running, but may as well try that if it doesn't work KOEO. You press the OFF and FLOOR buttons at the same time, release them and within 2 seconds press the AUTO button. "FLOOR buttons" is plural since you are pressing two buttons, OFF and FLOOR. You want to use the button that is for only floor airflow.
-Rod
Old 03-19-2008, 10:06 PM
Well Shorod I tryed it and it still operates as if I wasn't trying to get a code, tryed several times,, what do u think?
