Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-14-2008, 07:31 PM
Todd1963 Todd1963 is offline
Help: need 1995 Caprice Classic tune-up advice
Hi folks
I just had the fuel pump replaced in my '95 Caprice Classic that has the 4.3 L V8 and 72 k on it. (The engine wouldn't even turn over and obviously wasn't getting any gas.) After the fuel pump was replaced, I'm still getting some loading up/hesitation and even a stall once in a while when it is cold or has been run mostly in town.
I am the third owner and I'm pretty sure the car has never been tuned. My youngest boy and I love the car, but I've put a ton of money in it in the last year (alternator, AC compressor, suspension etc.). So does anyone know of a good basic tune-up combination of parts (distributor cap, plug wires, plugs) that would help performance but not cost an arm and a leg? My mechanic says the replacement caps are expensive for that engine.
Any help or advice is most appreciated.
Todd1963
Old 03-14-2008, 08:23 PM
rhandwor rhandwor is offline
Re: Help: need 1995 Caprice Classic tune-up advice
Put in new AC spark plugs. Ohm each wire for continuity as you do the plugs.
If bad it is usually within 2 or 3 inchs of the plug. If you have a tool you can repair. Inspect the rotor and distributor cap. Replace any bad parts.
Spray around the intake manifold and if it smooths out fix the vacuum leak.
Old 03-14-2008, 09:32 PM
Johncrow Johncrow is offline
rhandwor what exactly do you spray on around the intake manifold?
Old 03-15-2008, 07:22 AM
I use carb cleaner it will mask a leaking intake. This lets you know you have a leak.
Old 03-15-2008, 07:52 PM
4evrbad 4evrbad is offline
change your in-line fuel filter. it is recommended at least once every other year and will cause hesitation- very cheap and easy to do 10- 15minutes max and maybe $10
Old 03-15-2008, 07:59 PM
also if that doesnt cure the hesitation next i would change the coil. but the filter should do it i had the same problem when i took off my filter it was so clogged i could hardly blow through it (poor fuel pump was working very hard...also the reason why they fail early)
