Old 03-14-2008, 06:36 PM
skyjack skyjack is offline
key stuck in ignition
i have a 2000 granprix gt that has the key stuck in ignition the colimn wont show the position the gear is in is there a adjustment or something i can do to correct this prob? and how do i do it thx
Old 03-14-2008, 06:48 PM
blackdragon57 blackdragon57 is offline
Re: key stuck in ignition
Page 2-38 of your owner's manual describes a possible solution for your problem. Your vehicle won't allow you to remove the key if the car isn't in Park. Consequently, if your key is in the ignition when your battery dies, your vehicle will not allow you to shift and/or remove the key. If you are unable to shift your vehicle into park for some reason, you need to use the Shift Lock Override.
To use the slot:
1. Verify that the shift lever is in PARK (P) and that the shift lever button is fully released.
2. Locate the override access slot on the upper right side of the shift panel.
3. Remove the override access slot cap.
4. Insert a key or screwdriver into the access slot, press in and hold.
5. Press the shift lever button and hold.
6. Remove the key or screwdriver from the slot.
7. Pull the shift lever into the desired gear position.
8. Reinstall the override access slot cap."
I hope this helps.
2000 Grand Prix GTP 2-door (Gold Edition)
Fender-well Intake, 3.0" Modular Pulley, Ported & Polished SC, ZZP XP-Hotcam, 105# Valve Springs, Autolite 103's, Mod'd Retainers, DHP 1.0 PCM, Meziere Billet Flex Plate, SD Ram-air Hood, Pacesetter 2000-degree Coated Headers & Downpipe, Magnaflow High-flow Cat, SLP Powerflo System (2.5"), 180-degree Thermostat
Old 03-16-2008, 11:46 AM
i would like to know how to fix this prob? thx
