Go Back   Automotive Forums Car Chat > Lincoln > Mark VIII
Old 03-14-2008, 11:07 AM
mmcginnis46350 mmcginnis46350 is offline
No Brake Lights and Gear Shift Problem (1993)
My brake lights dont come on when the brake pedal is pushed. However, the turn signals and driving lights work. Also, my gear shift won't come out of park when the brake pedal is pushed. I'm assuming these are both from the same issue. Does anyone have any suggestion on what to check/fix?
Old 03-15-2008, 02:50 PM
Re: No Brake Lights and Gear Shift Problem (1993)
I did a continuity test on the brake pedal switch and it is working the way it should be. So, that's not the problem.
Old 08-11-2009, 08:23 PM
98LSCBRONCOM 98LSCBRONCOM is offline
Good Eve,
Any resolution to this? HAve the same problem occuring on my 1998 and mechanic disconnected harness for rear lights and still blowing fuse.
Thanks for the help!!!
