Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Exterior | Wheels | Tires
Exterior | Wheels | Tires This is the place for all exterior modifications including wheels and tires.
Old 03-14-2008, 09:54 AM
gorgepr gorgepr is offline
Question whats the backspace on T/A and camaro rims?
im looking to buy a pair of weld racing rims for my 94 T/A I found a pair with 30 x 10.5 slicks on them for 400 buck the rims are 15x 10 with chevy bolt patern, but the back space is 6.5 inches I want to know if they will fit my car or what is the back space of mi rims, I know its easy to messure but rigth now im away from home and im making the deal by phone so 6.5 inches will fit in ?
Old 03-15-2008, 01:22 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: whats the backspace on T/A and camaro rims?
The stock offset on the 93-02 wheels is +56mm. I'm not sure if you meant to say the wheel has a 6.5in offset. Because that would equal 165.1mm (our offset of calculated in mm btw). Then there's the question of whether that is a positive or negaitve offset. My first thoughts, no way that would ever work if it is truly 6.5in.
Here is a list that may help you:
To explain.. Say you want a 7 inch wheel up front, you would need one that has the offset of +35mm to +40mm, and you can fit the sizes 215, 225, 235 on it. Hope this helps.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 03-15-2008, 11:05 AM
I found this the offset is +25 mm, so could they fit in ?
Old 03-15-2008, 02:52 PM
GreyGoose006 GreyGoose006 is offline
backspace is simply the space from the back edge of the wheel to the surface where it mounts.
ideally, it should stay close to the same.
say that the stock wheel is 8" wide with 4" backspace.
that puts the wheel mount right in the middle.
if you go to a 8.5" wheel, a 4-4.25" backspace would work.
you wouldnt want to go lower than 4" though, or your wheels will stick out a lot.
common practice on the rear is to use as much backspace as you need to keep your wheels flush with the fenders.
on the front, you need to make sure that you can clear all the steering components
Old 03-24-2008, 06:31 PM
mikeemon's Avatar
mikeemon mikeemon is offline
Would you happen to have a similar chart for a 1979 Firebird?
