Old 03-13-2008, 06:56 PM
quadtrac quadtrac is offline
Adding Oil Pressure Gauge
GA_googleFillSlot("Forums_ROS_300x250_noad");var tcdacmd="sa=a;sz=3;ad";
i have a 2000 Grand am with the 2.4 motor, and I would like to add an Oil Pressure Gauge. Should I put in a mechanical or an Electric style gauge?? How is the best way to put in these gauges?? Thanks
Old 03-14-2008, 04:42 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Adding Oil Pressure Gauge
Electric for sure. They are a bit more expensive, but there's no risk of the extra hose breaking and spraying oil all over your cars interior. You could probably just buy the 3-wire sensor (opposed to the 1-wire switch that's in there now) and connect the extra wires to the guage. You'll also need the connector for the 3-wire. Just remove the switch in the head and install the sensor. Make sure the resistance works for the guage you buy.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-14-2008, 07:14 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
yeah definatly buy the oil pressure sensor for that particular gauge, or it might not work right.
electric is the way!!
1999 Grand Am SS 3.4 OHV
