Old 03-13-2008, 12:34 PM
rsmithusw rsmithusw is offline
Unhappy Timing Belt Replacement
I have a 2000 dodge caravan with the 2.4 liter 4 cylinder engine, I to replace the timing belt, but we can't get the crank pully off, is there a secret way of pulling it off? We have been using a slide hammer with 3 prong end... Also where do we line the cams, and crank up to place the new belt on it?
I have been working on this van for 4 days now, and can't seem to get any help around here, cause no one knows anything about the 2.4 liter dodge engines!
Richard
Old 03-13-2008, 01:10 PM
Unhappy Timing Belt replacement problems!
I have a 2000 dodge caravan with the 2.4 liter 4 cylinder engine, I am having problems getting the crank pully off, and need information on how to line up the duel cams, and crank to place the new timing belt on!
Can anyone help, been working on this van for 4 days now...
Thank you
Richard
Old 03-13-2008, 04:50 PM
Stretch58 Stretch58 is offline
Re: Timing Belt replacement problems!
Thank you
Richard
Richard--If you are near a parts house, get a Chilton book on your van, it has the procedure for replacing the timing belt on the 4 cylinder engine, including how to pull the crank pulley. #1 is how to line up the timing marks on the cam sprockets and crank sprocket BEFORE you take off the belt. That is an interference type engine so don't turn the crank with the belt off.
Retired USAF/ Nuclear Plant Controls Dude
Had Recently
1996 Caravan 3.0 Great Car
2005 Impala 3.8
Now
2000 GC 125K 3.3
2006 T&C 3.8
Old 03-13-2008, 05:19 PM
Thank you
Richard
One more thing,, I forgot about the free on line repair manuals. Look on this forum down a few subjects for the thread on the free online manual. eventually you will get to your engine(I looked, its there).
Had Recently
2005 Impala 3.8
Now
2000 GC 125K 3.3
2006 T&C 3.8
Old 03-13-2008, 09:28 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Timing Belt Replacement
Richard
Welcome to AF. Sorry but Pontiac Grand Prix is the wrong forum to get help with your car and I don't think we can be of much help to you. I see you have a post at the Caravan/Voyager forum so I have merged your new post with that thread. Good luck!
Timeslip 08/12/06
AF Community Guidelines
Old 03-13-2008, 10:18 PM
tempfixit tempfixit is offline
Call Autozone to see if they have a crankshaft pulley/harmonic balancer puller in their LOAN A TOOL PROGRAM or purchase a harmonic balancer puller I have seen them at ACE HArdware, I am not sure but it seems like around $25.00. There should be some bolt threads in the middle to the balancer that you can attach the puller to, which also has a large bolt that sets against the crankshaft that can be turned to remove the balancer. A sliding hammer does not have enough force to remove a tight fit balancer. Also check the balancer when you have it removed for damage from the sliding 2 pronge puller.
Hope this helps
Old 03-15-2008, 08:02 AM
Have you been successfulat getting balancer off??
Old 01-24-2009, 08:42 PM
brad mault brad mault is offline
trying to install engine in a 2000 dodge stratus,no clearence from oil filter housing to trans. bell housing.....thank you
Old 01-24-2009, 10:53 PM
brad mault you would be better off posting a new thread in the Stratus forum.
