Old 03-13-2008, 07:17 AM
jrichardson42 jrichardson42 is offline
No Start S-10?
I am a new member and i have a 02 chevy s-10 pickup with 2.2 with 5-speed trans the truck will start up and run for a little while then will die and when i try to restart it it wont turn over but if it sits a few hours it will start and then die the battery is good and has a new starter i talked to the dealer and they said it could be an ignition switch or the case that holds the ignition switch that piece stores the code for the passlock so i changed the ignition switch the lock cylinder and the lock cylinder case and i had to have it towed to the dealer to have the passlock reprogamed then they called and said it was done went to pick it up and i started it up and it died right there and would not start they dont know whats wrong with it so any help would we very helpful
Old 03-13-2008, 12:44 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: No Start S-10?
Did they offer to scan the computer?
When an ignition coil starts going bad, it'll provide sufficient voltage to light a spark plug UNDER COMPRESSION when cold but break down and start shorting out when it gets warm only to return sufficient voltage when cooled back off.
Old 03-13-2008, 01:56 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: No Start S-10?
Does the starter quit or the engine just will not start?
Does it start and run 2 seconds and the quit?
Does the security light come on for bulb check key on and then go off or stay on?
Has the fuel pressure been checked.
When not start check fuel pressure and for lose of good hot blue spark to spark plugs.
Not much of a dealer if they can not figure it out.
Tip on going to the dealer
Ask that only a factory certified gasoline engine performance specialist work on your car.
Not all dealerships are concerned with how repairs are dispatched, and not all dealership techs bother to take advantage of the training offered by factory (the vast majority of which is paid training). If the dealer is uncooperative, ask for your money back and call around for a dealer that will accommodate you.
MT
Old 03-17-2008, 05:53 AM
Re: No Start S-10?
When it dies it wont turn over but if it sits for a while and then it will start after it runs for about 10 min or so it will die.The dealer said the under hood fuse block could be bad or the ignition switch and i just replaced the ignition switch and lock cylinder and lock cylinder case.I think the dealer is just guessing now i dont think they know what there doing.
Old 03-17-2008, 09:37 AM
MT-2500's Avatar
AF - Advisor
Re: No Start S-10?
When a no start does the starter crank the engine good?
When It dies it needs to be checked for spark to spark plugs and fuel pressure up to specs.
Are you going to find another repair shop or dealer or try to fix it yourself?
MT
Old 03-18-2008, 08:40 AM
Re: No Start S-10?
There saying now its the under hood fuse box or a short in the wiring
Old 03-18-2008, 09:56 AM
MT-2500's Avatar
AF - Advisor
Re: No Start S-10?
That covers a lot of area!!!
I would find a good repair shop that knows what they are doing.
I would start with a good battery and charging system check and cable cleaning cleaning and check.
Good Luck
MT
MT
Old 04-20-2008, 10:00 AM
Re: No Start S-10?
We got the truck back a few weeks ago and it started doing the same thing you drive it for about a week and when you go to start it it wont turn over and no fuel pump pressure and the wierd thing while it wont start the hi-beam inicator light on the dash is on and if it sits for a day it will start and run for about a week.It has a new ecm new ignition switch and lock cylinder and the dealer replaced a fuse link and the under hood fuse box i dont know what else it could be.
Old 04-20-2008, 10:17 AM
MT-2500's Avatar
AF - Advisor
Re: No Start S-10?
If the starter does not crank the engine over.
You need to test it when it does it.
It is losing something someplace.
Lose wiring or connection or ground.
Check all power feeds and grounds when it does it.
MT
MT
Old 04-21-2008, 02:36 PM
Re: No Start S-10?
I was talking to another tech a another dealership and he said on 2000 to 2004 S-10s there is a little black box up under the drivers side dash he said goes bad he said when it wont start he said to turn the key and it should click but he couldnt remember what it was called so does anybody know what im talking about
Old 04-21-2008, 04:15 PM
MT-2500's Avatar
AF - Advisor
Re: No Start S-10?
STARTER RELAY
Yes it should click in start position and put out 12 volts on the starter solenoid wire.
It is also fused.
Also there is a crank fuse and a saftey switch that the start circuit has to go threw to get to starter.
Check everything on the starter circuit from ign switch to starter solenoid when it no starts.
Does the starter solenoid get 12 volts on the purple wire at starter solenoid.
Are all battery cables and ends good and clean?
Battery up good?
MT
