Go Back   Automotive Forums Car Chat > Ford > Super Duty
Old 03-12-2008, 10:24 PM
levigilbert levigilbert is offline
99 F-350 Diesel Cutting Out Under Load
My 1999 F-350 diesel w/ 200k cuts out under load at a certian position in the gas pedal. It has a six speed in it but it is almost like it is looking for the passing gear. I bought it used so it could have a different computer in it I guess. If you push down farther or let up on the pedal it takes off just fine. Is the a way to bypass a passing gear on the computer?
Old 03-16-2008, 11:01 PM
gungho's Avatar
gungho gungho is offline
Re: 99 F-350 Diesel Cutting Out Under Load
I would bet that the pedal switch is going bad. I don't know how to test to see if it is, but i'll do some more research. About what RPM does it cut out?
2000 f350 4x4 PSD-my baby
4" turbo back exhaust, Garrett ball bearing turbo, ATS Tranny/w triple disc convertor, electronics for tranny and motor, Duel HPOPs, 80hp injectors, 4:ll gears, 4" lift, 35" tires, custom bumpers
73 F250 390 motor-in the middle of a ground up rebuild
99 isuzu rodeo-my PIA so far
3.2L 106,000
Old 03-16-2008, 11:06 PM
gungho's Avatar
Do you have any check check engine lights? Couple of things to look at would be the CPS. A friend of mine also said that his was cutting out because of a loose connector on the valve cover.
3.2L 106,000
Old 03-17-2008, 05:09 PM
AmysTrooper's Avatar
AmysTrooper AmysTrooper is offline
TRY cps first but most likely the throttle postion sensor, You will have to replace the pedal assembly if its that, which I bet it is.
