Old 03-12-2008, 02:52 PM
scott83 scott83 is offline
fuel pump wont pump
i have an old 76 chevy p/u with a 350. thought the fuel pump was bad. Put in a new pump and it wont pump. all the lines are good and i made sure that the push rod was in the correct position. Could the cam be worn down and not pushing the rod down for it to pump? I even put some gas in a pop bottle and put a rubber line down in it and it wouldnt even pump the gas out of it. The old pump was still good.
Old 03-12-2008, 03:50 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: fuel pump wont pump
It could be worn down, but I doubt it. How many miles are on it? I would pull the cover off the block and take a look just to be sure. My '86 has 169,5xxx miles on it and when I replaced the pump a few thousand miles ago the cam still looked good.
If it is worn down, I would just install a blockoff plate (available from Sumitt and probably other places) and use an inline electric pump.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-12-2008, 04:08 PM
well its actually a mini pumper fire truck. it has 129xxx on it but several hours on top of that. when we took the old fuel pump out the push rod was slightly bent. we put a new push rod in it. yeah i have a electric line pump, we are gonna try to put that on.
Old 03-12-2008, 05:13 PM
rockwood84 rockwood84 is offline
does the new pump croak when you move the pump lever? if not the the new pump is bad.
Old 03-12-2008, 08:37 PM
i didnt check the new one to see if it did
Old 03-12-2008, 08:51 PM
jasom jasom is offline
Was it atleast running before you changed the fuel pump? If not and the fuel pump is fine I would be pulling the distibuter cap and see if the rotor is turning.
Old 03-12-2008, 09:53 PM
well no cause it wouldnt pump gas but if you put a little bit of gas in the carb it will run and run fine til you burn up the gas
Old 03-13-2008, 04:02 AM
jonnik jonnik is offline
Check to see that the push rod is the correct length.
Old 03-13-2008, 04:51 PM
j cAT j cAT is offline
if the fuel pump arm was bent then you have a problem in the engine normally the spring breaks or diaphram ruptures..
Old 03-14-2008, 05:01 PM
it wasnt the arm that was bent. it was the push rod that operates the fuel pump.
Old 03-14-2008, 05:02 PM
also the push rod was the same length and diameter
Old 03-14-2008, 05:13 PM
i would remove pump and manually see if the pump will pump... but i would see if gas line is not rusted out....the line that feeds pump... if this line has a hole in it it will only suck air!!!!
i would try to pull gas from tank threw the line that feeds pump use a siphon etc... see if you can pull out gas from tank......
Old 03-14-2008, 08:51 PM
777stickman 777stickman is offline
So, you say the fuel lines are good. You say the pump push rod was bent. You say the old fuel pump was good??
So what would cause the push rod to bend?? The only thing I can come up with is a frozen fuel pump, but you say it was ok.
Here's what I would do to check check the cam lobe for the pump.
1. Disable the engine ignition system.
2. Pull the pump mounting bracket off the block.
3. Here's the tricky part. Put the push rod in and have someone crank the motor while you feel the push rod end for movement. I don't know the exact lobe deflection but I would think somewhere around 1/2 inch of rod movement would be sufficient.
4. Good luck and be careful.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-15-2008, 11:57 AM
i believe that the 1/2in movement is correct on the arm... if the pump is mounted with the bolts loose he should see the pump movement upon cranking engine.....
Old 03-17-2008, 11:30 PM
ok ill remove the pump and see if the push rod has movement
