Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
View Poll Results: Has anyone experienced this before?
Do you the I have a defective new brake light swith? 0 0%
Do you think I have a bad PCM? 0 0%
Doy you think I have a bad ECU? 0 0%
Do you think I have a bad ABS controller 0 0%
Do you think I have a bad ABS Relay 0 0%
Do you think I have a bad rear speed sensor? 0 0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Old 03-12-2008, 12:12 PM
linkdaddy linkdaddy is offline
Unhappy 2000 E350 Brake & ABS light on OBD2 Inop
I have a 2000 E-350xlt 6.8l V10 with 330,000 miles excellent condition except recently the ABS & Brake lights are illuminated & the OBD 2 connnector will not power scanner to retreive codes (if any). I connected my scanner to the OBD 2 connector and the scanner would no power up (however the scanner does work properly on my other vehicles). I replaced the brake light switch (purchsed @ Autozone) & cleaned the rear axle speed sensor & connector with the battery disconnected. Started vehicle & Brake and ABS light reappeared after 10 seconds. Restarted van, Brake & ABS lights illuminated after approx. 30 seconds & remain on.
Old 03-14-2008, 03:42 PM
rhandwor rhandwor is offline
Re: 2000 E350 Brake & ABS light on OBD2 Inop
Normally the cheaper scanners won't pick up anti lock brake codes. Auto Zone and Advance offer free testing. I would try them otherwise you can pay for a test at some independants.
Check fuses, grounds and all electrical connections. If you have a problem with the unit http://www.modulemaster.com/ rebuilds them.
Sometimes you can clear codes and see what happens. If you recently did a brake job sometimes you can rebleed. Different pressure between front and year.
Old 03-15-2008, 11:34 AM
Thanks rhandwor, I did have a blown fuse, I replaced it and now the Datalink connector works fine and I replaced the rear ABS speed sensor and the the Brake & ABS light have dissapeared (everything is back to normal)
