Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-11-2008, 09:00 PM
FluffynTex FluffynTex is offline
Recharging AC coolant question
I have a 1991 Olds Cutles Ciera and the ac needs recharging with coolant. How do I know what kind to use? I was told if it was changed to the new 134a there would be a sticker under the hood saying so. But I find no sticker anywhere. Is there any way to tell for sure whant kind mine takes? I have both kinds as well as the hoses to put it in with I just dont know which to use in this particular car.
Old 03-12-2008, 01:27 AM
Dastardly Dastardly is offline
Re: Recharging AC coolant question
Should be on a yellow sticker. Mine is on drivers side under the hood, on the round bump where the shock/strut goes up into lol. Sorry I don't know what to call it. Or near where the hood latch is.
I did a search on autozone.com with your model car/year and shows R134A.
I'm sure someone here can verify this to be sure though.
Old 03-12-2008, 03:24 AM
72chevelleOhio 72chevelleOhio is offline
An easy way to tell if its R12 (freon) or R134a is the service ports. I THINK your low side service port is on the accumulator/drier. High side is usually in-line somewhere (maybe near the condenser)...take the plastic cap off the connecter (if they put it back on, and regardless of which refrigerant both caps will unscrew), if the outside of the port has a screw on connecter (like an oversized tire valve stem) it should be R12. If it has a quick connecter (like an oversized air tool fitting) it should be R134a. BUT someone still could have mixed refrigerants....the ports are only a guide to what should be in there...
Old 03-12-2008, 08:36 PM
3100MPFI 3100MPFI is offline
Send a message via AIM to 3100MPFI Send a message via MSN to 3100MPFI
R134a didn't become common in these cars until 1994. Sites like Autozone list R134a for ALL cars seeing that if you don't have R134a already, they want you to switch too it.
Look at the refilling ports and see if they look like tire fittings. If they DO, then look for a refrigerant called FREEZE12. It is a R12 replacement that is not hazardous to the environment, and is cheaper than real R12. It also works a LOT better than the R134a conversion.
