Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-11-2008, 07:46 PM
Micjohvan Micjohvan is offline
Send a message via AIM to Micjohvan Send a message via MSN to Micjohvan Send a message via Yahoo to Micjohvan
Installing a new Head. Any tips?
Ok so many of you are aware of the problems I have had with my 91 TSi.
I bought it with a dropped valve in the first cylinder.
I finally got the head to a machine shop and all the valves were toast, the head also was bad, junk if you will.
I went out to a local forign junk yard I know and the guy pulled a 92 head off a N/T car for me. Its a mitsu head rebuild job with I would guess less then 20k on the head and new valves and everything. Thing looks great!
So, now Im cleaning up the block getting ready to put the new head on. when I pulled the old head I slid the timing belt off the camgears and pulled the head. I was planning to mount the new head and slide the belt back over the new gears and dead time it. Does this sound like a workable idea to you pros?
I have never worked on the 2.0. Only 1.8s and with those you can snap a t belt and pull over and slide a new one on and off you go,freaking bullet proof.
I have bought a new HG and new headbolts. Anything else I should be aware of or be careful about. Any tips on this?
Please let me know and thanks for your time.
Old 03-12-2008, 07:15 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Installing a new Head. Any tips?
Take your time when setting the timing on the motor. You dont want to have to pull it back apart cause your 1 tooth off. Also I would replace the timing belt if it hasn't been done in a while.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-12-2008, 09:41 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Water pump, and tensioer too man. Like siver said, don't rush the job.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 03-12-2008, 11:37 AM
The timing belt that is on it now (the one I slipped off) is a new one with less then 500 miles on it.
As best I can figure the old man who had the car before me snapped a timing belt and it bent some valves (not real bad) but not knowing it was a zero clearance motor he put a new T-belt on and ran it for a couple days until the valves got so screwed to hell one of them fell out of the head (snapped off at the neck)
So my T-Belt is good. Do I really need a new water pump a tensioner? The car only has 90k on the whole thing?
Old 03-12-2008, 12:49 PM
Holset powered 420a
You dont have, Some people recommend changing the the tensioner, its really your call. If you think it will last another 60k of so them dont change it. I didn't change mine with the timing belt, but then again your car is also 17 years old.
The water pump is ofter changed also. Since water pumps tend to go out around 100k or so they dont want to have to tear the timing belt back off 15k later when the water pump dies.
98 Eclipse GS Turbo
2001 BMW 325i - DD
