Old 03-11-2008, 04:34 PM
fempersi fempersi is offline
rear main seal
83 S-10 2.8 L V6 - REAR MAIN SEAL IS IT THE 5mm TWO PEICE OR THE 5mm ONE PEICE, HELP.
Old 03-13-2008, 10:52 PM
Cam1959 Cam1959 is offline
Post Re: rear main seal
I dunno. But I was told long ago by friend mechanic at GM garage that these engines need half inch higher oil level to keep enough to rear main seal.
Maybe if you leaking bad, a good temp fix would be a good rubber seal revitalizer that expands the rubber, like "Wynns" rubber seal revitalizer.
I saw it expand old rubber , it can work.
1983 S10 4WD carbed 2.8L automatic w A/C
Old 03-15-2008, 07:53 PM
rhandwor rhandwor is offline
Re: rear main seal
Stop at a parts store and look at one. A two piece you pull the oil pan to put in, a one piece you pull the transmission. A lot easier if two wheel drive.
