Old 03-11-2008, 03:07 PM
cs7025 cs7025 is offline
2000 S-10 fuel pump info
I need the location of the fuel pump reset button
Old 03-11-2008, 03:49 PM
tempfixit tempfixit is offline
Re: 2000 S-10 fuel pump info
I am unaware of a fuel pump reset button, when you turn yourn key to run position with out the engine running the fuel pump will engage for 2 seconds and shut off. If fuel pmp is not working try tapping the bottom of fuel tank with a rubber mallet, this will sometimes jarr the pump gears loose and it will work again. If this happens replace fuel pump for it will leave you stranded somewhere. Check your fuel pomp relay.
Old 03-11-2008, 06:45 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Only ford have them things.
Check fuses and for power on gray wire from relay to fuel pump.
What engine?
Some chev do have a fuel pump prime connector.
MT
Old 03-11-2008, 08:39 PM
re: fuel pump switch Thanks for the info.
