Old 03-11-2008, 09:13 AM
fearnot fearnot is offline
Would it be terrible to re-use rocker bolts?
We have to get these heads on and the dealer says a few days for rocker bolts.
Would it be awful to re-use the rocker bolts.
Ian
Old 03-11-2008, 04:22 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Would it be terrible to re-use rocker bolts?
Unless there was a catastophic valve train failure, I see no problem with re-using the rocker arm bolts. The recommendation of replacing them is not a part of any proceedure I've ever seen.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-11-2008, 08:50 PM
wafrederick wafrederick is offline
Banned
Reuse them and I never had a problem with them failing.Make sure you don't hear a Snapping noise,the pedistalls breaking in half due to being reefed on.I have seen this happen for the first time a while back
Old 03-11-2008, 11:35 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
guys, should he add some threadlock to the bolts? Maybe tap out the threads and wire brush off the bolts to make a clean surface in order to get the correect torque value?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 03-12-2008, 05:52 PM
Banned
I don't torque them,I tighten them with my 3/8" impact wrench and check them with a hand ratchet.They have to be set in right,there is a slot in the head and in in the pedistal of the rocker arm.I have had this happen to me once,loosen up because it was not set in the slot right.
Old 03-13-2008, 05:42 AM
richtazz's Avatar
Yikes, an impact wrench (even a 3/8") on rocker arm bolts? I don't think I'd be using that technique. You're just asking to break a bolt, strip the threads in the head, or crack the rocker fulcrum/mount. Reinstall them by hand, torque to spec, done.
