Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 03-11-2008, 06:17 AM
92camarolt1 92camarolt1 is offline
t56
i have a 92 camaro with an lt1 put in it. i still have the 700r4 in it and i want the t56. would it be worth it, and does anyone have one they want to get rid of? how much?
Old 03-11-2008, 08:31 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: t56
Someone correct me if I'm wrong here, but I thought the LT1 and 700R4 do not go together.
Atleast not with some major fiddling of the PCM.
Old 03-11-2008, 08:43 AM
poormillionaire2 poormillionaire2 is offline
Re: t56
The 93 LT1's came with the 4L60, which was practically the 700R4. So some called it the 700R4.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 03-11-2008, 09:39 AM
Re: t56
its a stock rs 305 automatic transmission with an engine swapped lt1 in it, and running. ive only ever heard the transmission that i have being called a 700r4. so back to the original question?
Old 03-11-2008, 11:05 AM
wrightz28's Avatar
Re: t56
ehh Roger that, I always think they went directly to the 4L60e with the LT1, in which there would be controlling issues, my bad.
Switching from auto to manual is a little bit of a chore, in any application, the 700R4/4L60 is a fair all around auto trans. No doubt if someone took the time to put a LT1 in the car, the trans was seen some upgrade as well?
what rear end are you running?
Old 03-11-2008, 04:42 PM
Re: t56
It will take some work. You'll need a new crossmember, a place to mount the master cylinder, clutch petal, and all the little things that come with a manual tranny. Good luck.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 03-12-2008, 01:17 AM
Re: t56
its a stock rear end(10bolt) right now, but ive got the rear end that came out of the 94(12bolt), i just got to put it in.
wrightz28 sorry wasnt tryin to be rude, just blunt.
Old 03-12-2008, 08:24 AM
wrightz28's Avatar
Re: t56
Originally Posted by 92camarolt1
its a stock rear end(10bolt) right now, but ive got the rear end that came out of the 94(12bolt), i just got to put it in..
hmm, okay I believe those were 3.23's at best. Since you have a to rear swap already, I would put a 3.73 in ti, adds some "grunt feel" you know.
Poor pretty much covered all that needs to happen with the swap in a nutshell should you decide to carry forth with it. Me personally, although a manual is more fun to drive at times due to driver control, I would leave well enough alone and wrok on the auto. If it ahsn't been 'beefed', I'd throw in a shift improver and servo swap. The 700's can take some pretty hefty power.
No need to aplogize, didn't really catch anything there, I'm in that transistion phase from sometimers to alzheimers so sometimes my memory eludes me, especially in a swp situation such as this.
Old 03-12-2008, 11:23 AM
Re: t56
whats a servo swap?
Old 03-12-2008, 11:37 AM
wrightz28's Avatar
Re: t56
Corvette, 1st to 2nd servo, applies a firmer shift off the line. The 'Imporver kit' mainly focuses in the lag when you punch it from cruise. You may have noticed, when the 700 "kicks down" theres a brief pause until pressure builds and then it snaps into lower gear (and your neck )
Old 03-12-2008, 05:13 PM
Re: t56
94's came with a 10 bolt from the factory. Unless the 94 you are referring to has an aftermarket rear swapped in, it is a 10 bolt. And Wright is correct, the best ratio offered with the autos were 3.23's. You could look up the RPO codes for that car (if the rear is stock) or take the cover off and count teeth.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
