Go Back   Automotive Forums .com Car Chat > Ford > ZX2
Old 03-11-2008, 06:39 AM   #1
Acidbath
Acidbath's Avatar
Send a message via MSN to Acidbath Send a message via Yahoo to Acidbath
Time for a rebuild / tune up.. need advice..
Ok... well my friend has put quite a few miles on this thing... something around 130k. Just curiuous what I should replace on this thing to keep it running for another 130k.
As far as the cooling system, new cap, motorcraft thermostat, motorcraft water pump, and I'll flush him out and vac test it.
Engine? Not really sure, but preventative maintence makes me think about rod bearings. How "good" are they designed on these cars? (16valve Ztech) Is there a lot of flex in the crank? Should I look at main bearings too?
I know he will probally need a belt tensioner, timing belt is great idea (assuming this is an interference engine), he's got a code relating to the VCT.. gotta see whats up with that, possibly a bath in the solvent tank. I also want to reseal everything up with new gaskets, unless some are the heavy rubber kind that I could reuse.
Any and all sugguestions / tips would be appreciated. Thanks!
1992 Ford SHO.. New 0 Mile Short Block, Brass Plugs, New chrome fittings, and all new gaskets and seals, 3 angle valve job, new (used tensioners), new injector seals, caps, o-rings. New flywheel, new clutch, Sho Shop PP, ASP underdrive Pulleys, C&L 73mm, Ted B LPM, Reinforced Mounts, Poly Bushings all around, SHO Project Car Domain
Acidbath is offline   Reply With Quote
Old 03-11-2008, 06:52 AM   #2
Acidbath
Acidbath's Avatar
Re: Time for a rebuild / tune up.. need advice..
Also.. what kind of time frame should he have as far as having machine work done to the heads? Thanks!
