Old 03-10-2008, 10:50 PM
flashlight flashlight is offline
Camshaft Pulley
What is the best way to take the bolts off of the camshaft pulley? I got two of them off but I can't turn it so that I can get at the other two. So that I can get to the timing belt cover off to change the timing belt.
Old 03-11-2008, 12:00 AM
livid4fish livid4fish is offline
Re: Camshaft Pulley
Did you mean the crankshaft pulley? If so pull the e-break put car in neutral get 17mm socket to turn the crank over so you can get the other two bolts. Hope this helps.
Old 03-11-2008, 02:59 AM
Re: Camshaft Pulley
I did mean the crankshaft pulley not the camshaft pulley. I just mixed up what I was thinking when I was typing.
Old 03-11-2008, 06:11 PM
GunsBK314 GunsBK314 is offline
Re: Camshaft Pulley
I just pulled the cover off the other day. I'm in the midst of changing the timing belt myself.
I used a 1/4 drive, deep 8 mm socket. I accessed all four bolts from below the car, it is up on ramps.
Good luck!!
