Old 02-26-2003, 03:01 PM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
Styrene Question
Im starting a new project (supra) and im buildin a body kit for it... im wondering if u can Burn/Melt styrene, so taht it bends, because i have an area on the front bumper, that need to be flush with the bumper....
also, to glue the styrene onto the stock bumper, should i Use PUtty, or Superglue??
Putty:
Tamiya kinds: I will have to order, or buy off someone.... apx. 3wks to receive
or
Squadron: can get tmw...
What should i do?
Old 02-26-2003, 03:04 PM
Jay! Jay! is offline
Horizontally Opposed
Re: Styrene Question
Can you explain this more?
You may want a different solution other than 'burning/melting.' I think you'll find when you melt the plastic, it becomes a liquid (duh!), and will be very hard to control where it goes without some very specialized tools...
Hierarchy of Subaru:
(Click to see mine!)
clatescivicr clatescivicr is offline
Integra, I will have an extra Polyester Putty and Epoxy Smooth both made by Tamiya in the next week or 2. If you want them let me know.
I would think superglue, unless it needs to be molded in for a flush look.
Putty:
or
What should i do?
Clate - I'm back
Old 02-26-2003, 03:05 PM
Integra14's Avatar
Here, im going to go TAKe some pictures..... and ill try to explain what im trying to do..
Old 02-26-2003, 03:06 PM
God|Zilla168's Avatar
God|Zilla168 God|Zilla168 is offline
To bend styrene all you need is a little heat on the area you want to burn. I use a cigar lighter which is almost like a tiny torch to just heat the styrene enough so that is not melted but soft enough to bend. as to glueing it use the model cement to glue onto the bare part of the plastic and then sand. I hope this help.
Current project:
Mclaren MP 4/18
Old 02-26-2003, 03:15 PM
Integra14's Avatar
Heres the pic of the front bumper.... ps: 2nd custom job start!
Im trying to get the styrene, to Bend, and Stay in place... just like the front bumper
Old 02-26-2003, 03:25 PM
Hmm I see what you are trying to do.
That is a rather big bend to make. I am not sure if the styrene once bend will stay at that curve. My suggestion is for the end curve part just cut it off and start with a small piece of styrene but cut shaped into the curve you want then glue it back to the end of the straight piece.
Current project:
Mclaren MP 4/18
Old 02-26-2003, 03:42 PM
JDM Evo7 JDM Evo7 is offline
You can bend to that angle with no problem. Use a sheet longer than you need for better leverage, then cut off the excess. Soak the Styrene in very hot water, around 150-160 degrees and that will releax it enough to bend easily. Use model glue to bond the styrene to the model.
Old 02-26-2003, 04:43 PM
flyonthewall's Avatar
Car Mod guy
Cool! Someone is finally getting the idea about using styrene
First of all, if your glueing styrene to styrene then use the appropriate adhesive. Polystyrene cement will give a much better bond than superglue coz it will weld the join together.
To acheive what your tryingto do, i would suggest two ways to go about it. Perhaps the easiest option is to build up a sandwich of severl layers of styrene to form a solid piece. The best way to go about this is have a template, made from card, of that single bottom piece and work from that. Cut it out several times from a thicker sheet of styrene then you'll have identical pieces to keep things symetrical.
Secondly, you could glue a piece from thin sheet - .010 - to the face of the bumper, then glue piece from thicker plastic that has been cut to fit, in from behind. You could repeat this a couple of times so its solid, maybe add a little putty to fill small gaps then sand the face of the bumper so its flush as you required... Is this making sense?
Does this help you at all?
BTW- forgive the crude drawings
Old 02-26-2003, 04:45 PM
I'd also recommend you put a few vertical ribs behind that area to support and shape the plastic, and make sure it only bends along the planes you want it to...
Old 02-26-2003, 05:45 PM
Integra14's Avatar
Thanks Chris.... i am going to try the Stacking Technique, so i do't have buy more styrene... thanks a lot, and does anyone have any suggestoins what i should do for the GAPING whole in the middle?
Old 02-26-2003, 06:05 PM
chaos's Avatar
chaos chaos is offline
AF Premium User
[b]Cool! Someone is finally getting the idea about using styrene
Chris, when you say sandwich - I assume you mean building horizontally - the different colours in your illustration are meant to be the layers?
Old 02-26-2003, 06:14 PM
Car Mod guy
U got it!
Old 02-26-2003, 06:23 PM
chaos's Avatar
AF Premium User
U got it!
Cool! What thickness of styrene do you suggest? Also, I am also assuming (too many assumptions! ) that after building it up, it needs to be smoothened (sp) with putty - to prevent the ridges from the layers showing?
Old 02-27-2003, 05:35 AM
Car Mod guy
Exactly! The thicknesses i use are .010, .020 and .030 along with any other strips and shapes that could be useful such as channels, 'L' shaped strips, rob, tube and square shape strips. An assortment of thin strips is very useful for detailing and saves the troble of cutting them from the sheets.
2000 E150 question ZZT Econoline 1 11-25-2009 11:15 AM
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
styrene question fat_fridge Car Modeling 8 06-27-2005 10:47 AM
Styrene question dojaja Car Modeling 33 06-04-2004 11:03 AM
styrene questions tc3 Car Modeling 8 04-22-2003 07:39 PM
