Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 03-10-2008, 10:25 PM
chevyrulespops's Avatar
chevyrulespops chevyrulespops is offline
I want to purchase the derale 16927 dual fan
I now have a ram jet 350 engine which was running extremely hot..I upgraded to a be cool radiator and now Im shopping for a fan....my concern is the rated 50 amp draw...I have a v8 alternator...does anyone have any experience with this fan...recommend buying it or not?
Old 03-11-2008, 08:26 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: I want to purchase the derale 16927 dual fan
You need to look at the amperage output capacity of you alternator. And for that high of rating, you should want to upgrade the wiring to hold up that much flow, maybe even add a fuse.
Sure you have the ign. timing right? Too far advanced and things will heat up in a hurry.
Old 03-12-2008, 10:54 AM
I did remember checking the timing when we first turned it on. We did get the timing correct since we had to install the diagnostic check tool to temporarily disable the computer. But at that time I was running the small v6 radiator with the single fan. (This is my first hot rod project) But the recommendation for a high output alternator makes alot of sense especially since I have a sound system. I think i took out the alternator from a 88 or 89 caprice. I need to check the amperage...I know that the alternator was handling the juice alot better than that lame v6 alternator, since i had the system blasting and it hardly put a dent in the charging...maybe I can use the same one I got or upgrade if it doesnt...thanks
I read somewhere that someone used one fan on all the time linked with the ignition system and then linked one fan with a temp switch and that worked for him. What do you think about that set up?
Old 03-12-2008, 11:30 AM
wrightz28's Avatar
There should be a single wire (tan) hookup with a quick disconnect up by the firewall, right hand side. Disconnect that to set the timing appropriately.
I'm not overly sure what the standard Caprice alternator rating was, but normally GM's of the era ran around 85 amps. A civil package may run a 120-125A (which sounds like a fair rating for what you need).
For the fan, I would go the easy route and buy a kit that incorperates a temp sending unit in the radiator versus hardwiring it to a hot ign. source, which would prematurely shorten the fan's life.
Old 03-12-2008, 09:32 PM
Thumbs up Re: I want to purchase the derale 16927 dual fan
Im going to purchase the fan this evening and then install it with a temp switch....I'll keep you posted on the outcome!!!
Old 05-10-2008, 02:26 PM
the fan will fit but only if you put it in backwards and cut off a piece of the metal shroud to allow clearance for the steering box. At first the down side was that the flaps that should be facing down are now up..That can be rectified by drilling the holes on the opposite side and reinstalling the flaps, they come off easy. For anyone else interested in getting a true 4,000 cfm dual fan set up here's the link http://store.summitracing.com/partde...5&autoview=sku
