Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 03-10-2008, 04:02 PM   #1
bellaluna953
95 Lumina Window prob
Driver side power window will go down but not up. All other windows working just fine. Checked fuse, seems to be fine. Can anyone give me a clue?
bellaluna953 is offline   Reply With Quote
Old 03-10-2008, 06:26 PM   #2
Bearwulf
Bearwulf's Avatar
Re: 95 Lumina Window prob
Check switch & connections in that door first. If seem good remove wires check motor. Should be a circuit breaker in system in the door, if window is jammed will pop breaker instead of burning out motor.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Bearwulf is offline   Reply With Quote
Old 03-11-2008, 12:33 AM   #3
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
My '97 does that from time to time...I just open the door, press and hold the button while I slam the door, and it goes up...
I suspect a lift motor going bad, but until the day it doean't come back up, I'm not messing with it.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 03-11-2008, 12:47 AM   #4
bellaluna953
Will give that hold button & slam a try. Thanks!
