Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-10-2008, 11:29 AM
tomtina200 tomtina200 is offline
1998 Ford Contour RPM High
Hello I am trying to find out if anyone knows what is going on. I drove to Houston from Dallas this weekend and when I arrived to Houston the car was fine. When I drove back home to Dallas. Suddenly at a stop light my RPM climbed all the way up to 3500 RPM by itself. I was not pressing anything. When I turned my steering wheel it even goes higher. I am not sure what is going on. My Car is a Manual Transmission and the only thing I can think of is that at the light the car was in Neutral, and had my feet off the accelerator and I was only pressing the Brake Pedal. I am not sure what is going on. Please help
thanks
John
1998 Ford Contour 2.5 L
V6 Manual Transmission
Old 03-10-2008, 04:30 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 1998 Ford Contour RPM High
In the FAQs on contour.org
http://contour.org/FAQ/FAQ.php?s=probs&displayid=7
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-10-2008, 04:34 PM
Thanks for the Help... Also do you know why my RPM even go higher when I turn my steering wheel??
Old 03-10-2008, 07:00 PM
Because its putting strain on the motor to run the power steering pump. Its the same reason why the engine idles higher whenever you turn on your AC to run the AC compressor.
"The CEG Nazi"
www.contour.org
