Old 03-10-2008, 09:42 AM
isukicker2004 isukicker2004 is offline
no reverse
I have a 2001 Bravada and a few days ago it all of a sudden lost the reverse gear . There is also a seemingly hard shift from 1-2. I have tried to search the forums as comprehensively as possible and did not find any post with the same issues. Could this just be a solenoid or a fluid issue, or am I in need of a rebuild?
Old 03-10-2008, 10:21 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: no reverse
any ses light? if the reverse solenoid went, it would set the light off. Otherwise you might have stripped the reverse gear if you were drifting foward then put it in reverse. Has the fluid/filter been changed?
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 03-11-2008, 08:58 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: no reverse
No reverse is internal.
But make sure the fluid level is good when hot.
Does it have all forward gears?
How many miles on it?
Pull the transmission pand and look for metal chips and stuff in bottom of pan.
A striped sun gear is a good suspect.
Usually drops metal chips in bottom of pan.
MT
Old 03-11-2008, 10:50 AM
Re: no reverse
Thank you for your replies! I took it into the transmission shop on the suggestion of my future father in law and found out that I had a crack in the case or something like that and the hard shift was due to no 2nd and also no 4th. It has to get rebuilt for around $1500. Does that sound about right for cost?
Old 03-11-2008, 11:24 AM
MT-2500's Avatar
AF - Advisor
Re: no reverse
Go for quality more than price.
But That price is good if it is a good quality rebuild.
With a good warranty.
And a good transmission shop.
I would watch the transmission chain stores.
Some good and some not so good.
Also Price out a GM factory rebuilt transmission.
3 year nation wide warranty and is for 50K and may be up to 75K now.
I would ask them more about and to figure out why the case cracked.
Good Luck.
MT
MT
Old 03-11-2008, 07:39 PM
83cutlass 83cutlass is offline
Re: no reverse
No reverse, second, or forth is the broken sun shell not the case. There is a GM bulletin for it. A complete rebuild is generally not necessary. All you need is the upgraded/hardened sunshell and related parts.
How many miles on the Bravada?
Old 03-11-2008, 08:12 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: no reverse
I agree with '83 cutlass, that sounds like the typical sunshell break/strippage. The '01's were suppose to have a better, updated shell. As for a rebuild, it depends on the milage. If its got high milage, it does not make sense to open the tranny up and just replace the shell. A rebuild at this point is a wise choice. Also clearly state to your rebuild shop that you want "the beast sun shell" Make sure they use these instead of a cheap aftermarket again....especailly if you plan on keeping the truck for a while.
